| DRPHIL914 |
Mar 1 2012, 09:05 AM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,907 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
http://www.sfgate.com/cgi-bin/article.cgi?...Q0X01-M04KS.DTL
or http://articles.cnn.com/2012-02-29/opinion...t?_s=PM:OPINION when i bought my 914 i was going to go EV IF i could not get the engine running, but did get it running and thus saw the $20,000 cost to convert using LiPo batteries, so passed for the time being. however, since my son is an engineering major at USC(south carolina) this subject keeps coming up. Hydogen, Propane, compressed natural gas, all options. this just came up yesterday with the high gas prices, Back in minnesota all of our busses ran on propane. so why not our 914's? (IMG:style_emoticons/default/confused24.gif) food for thought.... |
| underthetire |
Mar 1 2012, 11:26 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Hydrogen, I see a couple test cars running around here. The stuff has killed more fuel injectors than the wrecking yards! Also takes a huge tank to get any range out of the car, unless you use cryogenic hydrogen, but that's another can of worms. Not ready yet IMO.
Now, fuel cell technology is starting to really come together. Looking forward to that. Personally, I think a tiny diesel hybrid set up would be the ticket right now. If a jetta can get 50mpg, or a Prius can get high 40's with gas, imagine what a more fuel efficient motor with the hybrid could do. |
| zymurgist |
Mar 19 2012, 03:27 PM
"Ace" Mechanic ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
Personally, I think a tiny diesel hybrid set up would be the ticket right now. If a jetta can get 50mpg, or a Prius can get high 40's with gas, imagine what a more fuel efficient motor with the hybrid could do. (IMG:style_emoticons/default/agree.gif) I don't understand why manufacturers are building gasoline-electric hybrids. Diesel-electric hybrids seem like a more logical choice for fuel efficiency, plus they can run on biodiesel. |
| damesandhotrods |
Mar 19 2012, 04:11 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 568 Joined: 26-September 10 From: Santa Cruz California Member No.: 12,218 Region Association: Northern California |
Personally, I think a tiny diesel hybrid set up would be the ticket right now. If a jetta can get 50mpg, or a Prius can get high 40's with gas, imagine what a more fuel efficient motor with the hybrid could do. (IMG:style_emoticons/default/agree.gif) I don't understand why manufacturers are building gasoline-electric hybrids. Diesel-electric hybrids seem like a more logical choice for fuel efficiency, plus they can run on biodiesel. I don’t understand why they’re building gas/battery hybrids. Why don’t they build them like locomotives, a small dedicated combustion engine turning a generator to provide electricity for the electric motors? Why lug batteries around? |
| zymurgist |
Mar 19 2012, 04:24 PM
I don’t understand why they’re building gas/battery hybrids. Why don’t they build them like locomotives, a small dedicated combustion engine turning a generator to provide electricity for the electric motors? Why lug batteries around? Regenerative braking? In a locomotive, the current generated by regen is dissipated as heat by resistor packs. In a hybrid car, it's stored back in the battery pack. Not sure how much added efficiency this brings to the table though. |
| ClayPerrine |
Mar 19 2012, 08:23 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
I don’t understand why they’re building gas/battery hybrids. Why don’t they build them like locomotives, a small dedicated combustion engine turning a generator to provide electricity for the electric motors? Why lug batteries around? Regenerative braking? In a locomotive, the current generated by regen is dissipated as heat by resistor packs. In a hybrid car, it's stored back in the battery pack. Not sure how much added efficiency this brings to the table though. (IMG:style_emoticons/default/idea.gif) Instead of large, heavy battery packs, use a bank of large capacitors to store the electricity from braking. Then discharge the caps for acceleration. Make the engine large enough so that it can keep the car moving down the highway, with a little left over to keep the caps charged. When you need acceleration, discharge the caps. Plus you get the benefit of the engine running at a steady state all the time. The intake, valve timing, fuel mixture and ignition can be optimized for that exact RPM, instead of the compromise needed for acceleration an deceleration. |
| ThePaintedMan |
Jul 12 2012, 07:56 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,887 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States
(IMG:style_emoticons/default/idea.gif) Instead of large, heavy battery packs, use a bank of large capacitors to store the electricity from braking. Then discharge the caps for acceleration. Make the engine large enough so that it can keep the car moving down the highway, with a little left over to keep the caps charged. When you need acceleration, discharge the caps. Plus you get the benefit of the engine running at a steady state all the time. The intake, valve timing, fuel mixture and ignition can be optimized for that exact RPM, instead of the compromise needed for acceleration an deceleration. This is exactly what the Toyota TS030 was equipped with at Le Mans this year. Google it, very cool. In theory, battery-electric hybrids are most efficient/useful because they capitalize on the majority of driving done in the U.S. - around town or stop and go. If you have a plug-in like the newest Prius or Volt (if you can look past the awful styling), you have the ability to run all day on electricity alone. Convert the power to fluid units, and it works out to be about 100 m.p.g in most areas. Of course the flipside of that is the majority of energy produced in the U.S. still comes from fossil fuels, namely coal. Whether you "agree" with where cars are heading, you have to admit that the push has stimulated technology development to heights we never thought were possible. I still say if you want to make cars more efficient, strip EVERYTHING out of them - leather, A/C. A Prius could probably do 90-100 mpg no sweat if it weren't such a pig of a car. Thats why I appreciate the simplicity of 914s. But times have changed and I would wager most people would never go back to the days of roll-down windows and no a/c. |
| broomhandle |
Jul 13 2012, 11:10 AM
Member ![]() ![]() Group: Members Posts: 290 Joined: 26-June 09 From: Half Moon Bay, CA Member No.: 10,512 Region Association: Northern California |
This is exactly what the Toyota TS030 was equipped with at Le Mans this year. Google it, very cool. and the Audi won.... E-tron. with regen braking. (IMG:style_emoticons/default/smile.gif) |
| ThePaintedMan |
Jul 13 2012, 11:49 AM
This is exactly what the Toyota TS030 was equipped with at Le Mans this year. Google it, very cool. and the Audi won.... E-tron. with regen braking. (IMG:style_emoticons/default/smile.gif) I vote for bicycles too, good call. Tired of carmakers (and everyone for that matter) talking about how sustainable their technology is. You know what is truly the only sustainable mode of transportation? The one that can be used over and over without any impact on the environment? Feet. But if you have to have a car, get one that fits your lifestyle and needs, not an Excursion that you drive an hour to and from the office to by yourself. Pointless. Yeah, the Audi used a massive flywheel that spun up, in a different regen-braking configuration. Essentially just a giant rubber band wound up. Very cool and practical for performance, but not as much for economy/efficiency. |
| broomhandle |
Jul 13 2012, 12:09 PM
This is exactly what the Toyota TS030 was equipped with at Le Mans this year. Google it, very cool. and the Audi won.... E-tron. with regen braking. (IMG:style_emoticons/default/smile.gif) I vote for bicycles too, good call. Tired of carmakers (and everyone for that matter) talking about how sustainable their technology is. You know what is truly the only sustainable mode of transportation? The one that can be used over and over without any impact on the environment? Feet. But if you have to have a car, get one that fits your lifestyle and needs, not an Excursion that you drive an hour to and from the office to by yourself. Pointless. Yeah, the Audi used a massive flywheel that spun up, in a different regen-braking configuration. Essentially just a giant rubber band wound up. Very cool and practical for performance, but not as much for economy/efficiency. well, it is a race car.... haha the little audi A2 or something e-tron is cool though. i agree. if you look at car ads turing the fule crissis in the 70's. like the original honda accord. its like ,and gets 36mpg... and like the new accord? its huge and no way is designed for mpg. fools..... |
| ThePaintedMan |
Jul 13 2012, 12:42 PM
well, it is a race car.... haha the little audi A2 or something e-tron is cool though. i agree. if you look at car ads turing the fule crissis in the 70's. like the original honda accord. its like ,and gets 36mpg... and like the new accord? its huge and no way is designed for mpg. fools..... Of course. I never expect a company like Audi to put economy over performance in their technological development. Especially not it the R18. Its cool either way to see people think of ways to use that energy that, to date, has been simply wasted as heat. Might as well do something with it. Yeah the Accord is a long way from what it once was. Even the Civic is huge now. Can't fault manufacturers for catering to what their market demands. But I get tired of listening to people complain about gas prices and how much it costs them. You bought the vehicle. You made the choice. If Honda truly thought they'd make more money with a stripped down gas-saver, I think the Accord would look a lot different. Good talk, Broom! |
| zymurgist |
Jul 13 2012, 12:47 PM
Yeah the Accord is a long way from what it once was. Even the Civic is huge now. Can't fault manufacturers for catering to what their market demands. But I get tired of listening to people complain about gas prices and how much it costs them. You bought the vehicle. You made the choice. If Honda truly thought they'd make more money with a stripped down gas-saver, I think the Accord would look a lot different. Good talk, Broom! (IMG:style_emoticons/default/agree.gif) I would love to see Honda make a CR-Z with the engine from my RSX and a manual transmission. I would totally buy one. (IMG:style_emoticons/default/driving.gif) |
Philip W. Aternative to the current gas prices? Mar 1 2012, 09:05 AM
jsconst Propane wouldn't help much in California, it... Mar 1 2012, 09:19 AM
monkeyboy
Propane wouldn't help much in California, it... Mar 1 2012, 09:50 AM
vsg914 That would be T. Boone Pickens, not Tbone. Mar 1 2012, 09:36 AM
Philip W.
That would be T.Boone Pickens, not Tbone.
:rot... Mar 1 2012, 09:44 AM
underthetire LiPo batteries are cheap now, just sayin. Mar 1 2012, 09:47 AM
scott_in_nh There isn't anyplace in the 914 I'd feel c... Mar 1 2012, 09:48 AM
billh1963 We are looking at wood gassification technology wh... Mar 1 2012, 09:55 AM
ThePaintedMan
We are looking at wood gassification technology w... Mar 1 2012, 10:03 AM
Cap'n Krusty As I understand it, there's less energy per un... Mar 1 2012, 09:56 AM
orange914
If I had to "improve" the fuel econom... Mar 1 2012, 02:12 PM
Bob L.
If I had to "improve" the fuel econo... Mar 19 2012, 07:44 PM
orange914
[quote name='orange914' post='1637232' date='Mar ... Mar 19 2012, 08:21 PM
billh1963 Propane isn't nearly as efficient as gasoline.... Mar 1 2012, 09:59 AM
rick 918-S In addition to the low energy, you need a large vo... Mar 1 2012, 10:08 AM
Philip W.
when... Mar 1 2012, 10:10 AM
underthetire Well, I was buying 1.5 Lipo's for my airplanes... Mar 1 2012, 10:26 AM
Philip W.
Well, I was buying 1.5 Lipo's for my airplane... Mar 1 2012, 10:40 AM
ape914
Well, I was buying 1.5 Lipo's for my airplan... Jul 15 2012, 12:59 AM
andys A guy I worked with 30 years ago had a propane Che... Mar 1 2012, 10:58 AM
Vacca Rabite
A conversion (electric, diesel, propane) is a sim... Mar 1 2012, 11:05 AM
Vacca Rabite I looked at LGP and LNG conversions for my old tru... Mar 1 2012, 10:59 AM
Philip W. http://www.switch2hydrogen.com/h2.htm
or hydrogen... Mar 1 2012, 11:03 AM
ruby914 When I started my build, I looked at the natural g... Mar 1 2012, 11:06 AM
Smitty911
I don’t understand why they’re building gas/... Mar 19 2012, 07:30 PM
orange914
:idea:
Instead of large, heavy battery packs... Mar 19 2012, 08:32 PM
ClayPerrine
[quote name='ClayPerrine' post='1649448' date='Ma... Mar 19 2012, 08:41 PM
ape914
:idea:
Instead of large, heavy battery packs... Jul 15 2012, 01:07 AM
ThePaintedMan
Fluid units??? why not just state the kwHrs / m... Jul 15 2012, 11:03 AM
Strudelwagon Guys, Speaking from experience (10 years in NGV Fl... Mar 1 2012, 11:48 AM
Philip W.
Hydrogen, I see a couple test cars running around... Mar 1 2012, 11:57 AM
ClayPerrine I did the research to convert my pickup to dual fu... Mar 1 2012, 12:02 PM
Strudelwagon
I did the research to convert my pickup to dual f... Mar 1 2012, 12:45 PM
02loftsmoor did you get the oil leak repaired on your 6 ?
... Mar 19 2012, 10:18 PM
ClayPerrine Nope. It is sitting in the garage, waiting for me ... Mar 20 2012, 04:31 PM
wingnut86 Phil,
I believe much of that research has been in... Mar 1 2012, 12:33 PM
914Sixer My company van is set up for CNG and we would love... Mar 1 2012, 09:53 PM
02loftsmoor there is a couple of CNG stations in San Antonio, ... Mar 19 2012, 10:15 PM
02loftsmoor for one thing T Boon is using Naural Gas, in his c... Mar 19 2012, 10:07 PM
ape914
for one thing T Boon is using Naural Gas, in his ... Jul 15 2012, 01:12 AM
pete-stevers this is a cool subject...it is the reason i keep a... Mar 19 2012, 10:37 PM
Madswede I agree, interesting topic. I like how it's mo... Mar 19 2012, 11:36 PM
02loftsmoor The USA is the 3rd largest producer of Natural gas... Mar 20 2012, 05:58 AM
johannes I watched this video yesterday...
aIFFFGf1ZRE
Af... Mar 20 2012, 06:05 AM
SLITS Pedal Cars will make a comeback!!! Mar 20 2012, 08:36 AM
jtg Gasoline? Propane? Natural gas? Not for me... Jul 12 2012, 07:00 PM
broomhandle its about what fuel is around.
i grew up on diese... Jul 13 2012, 10:51 AM
broomhandle http://www.914world.com/bbs2/uploads_offsite/i715.... Jul 13 2012, 01:13 PM
ThePaintedMan :rotfl: Awesome! I'm going to save that on... Jul 13 2012, 01:52 PM
johannes 9XUKOUbp_PA
muRuHA-MREs Jul 13 2012, 02:42 PM
lotus_65 see you in the market Jul 15 2012, 08:08 AM
bshounen best thing for the h4/6 is run it on e85. e98 if y... Apr 16 2014, 07:54 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:41 AM |
