> Best location for relocating fuel pump, Best location for relocating fuel pump
lonewolfe
post Jul 13 2012, 01:01 AM
I've searched this topic and found a little information but was surprised there was not more. The search engine on this site leaves a lot to be desired. Anyhow, I'm relocating my fuel pump to the front of the car. I do not wish to put it in the front trunk so that leaves under the fuel tank or underneath the car close to the master cylinder underneath the stearing rack cover. Which location is best in your opinion? Any pro's or con's to either location?
lonewolfe
post Jul 14 2012, 01:27 PM
Hey Spoke!
Thanks for letting me know about your thread. Unfortunately, 914World won't let me view any of of the threads to your post. I don't have any idea why this happens but it happens more often than not. When I clink on a link a screen comes up with a read bar stating page can't be viewed because of missing information. I log out, log back in and it still will not let me open the page. Very frustrating. So, I can't see the pictures of the work you did relocating your fuel pump. (IMG:style_emoticons/default/mad.gif)
lonewolfe   Best location for relocating fuel pump   Jul 13 2012, 01:01 AM
GeorgeRud   Unless you have the removable panel that was used ...   Jul 13 2012, 06:16 AM
lonewolfe   Unless you have the removable panel that was used...   Jul 13 2012, 07:09 AM
Tom_T   Unless you have the removable panel that was used...   Jul 13 2012, 12:54 PM
RobW   I put mine in the front trunk and it was fine. Eas...   Jul 13 2012, 07:17 AM
Cap'n Krusty   Remember, the fuel lines that run through the tunn...   Jul 13 2012, 07:33 AM
reharvey   Remember, the fuel lines that run through the tun...   Jul 13 2012, 09:51 AM
sean_v8_914   ...and since they will now be pressurized, the end...   Jul 13 2012, 08:49 AM
rhodyguy   one factor that never seems to be mentioned is how...   Jul 13 2012, 08:57 AM
wndsrfr   one factor that never seems to be mentioned is ho...   Jul 13 2012, 09:37 AM
sean_v8_914   i use the factory circuit. run the wire thru the t...   Jul 13 2012, 09:39 AM
reharvey   i use the factory circuit. run the wire thru the ...   Jul 13 2012, 09:52 AM
wndsrfr   i use the factory circuit. run the wire thru the ...   Jul 13 2012, 02:08 PM
76-914   :agree: Splice into your old electrical feed to pu...   Jul 13 2012, 09:46 AM
Bartlett 914   Since I had the fuel tank out of the car, it was b...   Jul 13 2012, 10:41 AM
lonewolfe   Thanks for all the great replies. 76-914, thanks f...   Jul 13 2012, 01:45 PM
Spoke   I relocated the fuel pump up front. Check my prog...   Jul 13 2012, 03:51 PM
lonewolfe   Hey Spoke! Thanks for letting me know about y...   Jul 14 2012, 01:27 PM
kg6dxn   Hey Spoke! Thanks for letting me know about ...   Jul 14 2012, 01:40 PM
kg6dxn   BTW, Mine is in the front trunk. I replace both fu...   Jul 14 2012, 01:49 PM
- Lo-Fi Version Time is now: 11th July 2025 - 04:01 AM
