Vinyl covering on FG parts / "A" pillar, most cost effective way or alternitives |
ruby914 |
Jul 26 2012, 12:38 PM
Senior Member Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None |
Some of you may have seen this "A" pillar with the tweeter boss mounted in my car before. The CF I have is cost prohibitive to reproduce.
I have held off modifying my "A" pillar mold, to include the boss, until I work out a solution for a nice OEM looking vinyl finish. I saw a pair of Morph's speaker pods at G&R that looked like they were covered with vinyl? They looked great. Is this how Morph is selling them or someone else's nice work? I picked up this very thin sticky back vinyl shelf paper at HD that actually looks great on flat surfaces. Just a little heat and it will couture but it is hard to control with out wrinkling. I made a crude picture frame to vacuum the HD vinyl over the part. That helped but It looks likeI will have to make a dedicated vacuum table and frame with some heat souse to get the quality I am looking for. I have seen some 3M vinyl that seems very pricey. I am not sure if that is what the dash recover guys are using? A more proper vinyl may help. After seeing a, complex shape, thermo formed ABS cover at work the other day I am also considering other options. An ABS with a surface finish on one side would make a nice part but with a cheaper nonOEM look. I have also seen some kind of over lay patterns that can be put on wheels, dash, grills... This was last seen up at Pomona Auto show. I was thinking some of you, Morph, may have connections or ideas to produce a hi quality low cost part . Your thoughts... Attached image(s) |
Rod |
Jul 27 2012, 09:18 AM
Senior Member Group: Members Posts: 616 Joined: 1-January 08 From: Farnham UK Member No.: 8,526 Region Association: England |
I used a good quality vinyl and with the right glue it's reasonably easy to get it to cover quite complicated pieces... It's the glue that makes the difference...
(IMG:http://www.914world.com/bbs2/uploads_offsite/i62.photobucket.com-8526-1343402313.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i62.photobucket.com-8526-1343402314.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i62.photobucket.com-8526-1343402314.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i62.photobucket.com-8526-1343402458.1.jpg) |
ruby914 |
Jul 27 2012, 12:04 PM
I used a good quality vinyl and with the right glue it's reasonably easy to get it to cover quite complicated pieces... It's the glue that makes the difference... (IMG:http://www.914world.com/bbs2/uploads_offsite/i62.photobucket.com-8526-1343402313.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i62.photobucket.com-8526-1343402314.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i62.photobucket.com-8526-1343402314.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i62.photobucket.com-8526-1343402458.1.jpg) Rod, That looks great! I like that shape, for a nice fit on the tweets. I think your curves are a little less extreme than what I have but that makes me want to give it a try. Maybe I don't have the best vinyl for this job. What I have only sees to stretch only one way and not very far. I will search for a more suitable auto vinyl as well as the thinner film. Thanks for sharing, looks great! Big improvement in the sound? Just got back from the paint store and all they had was the paint w/o the texture. I may have to order something off the net. Great leads and ideas guys, thanks. |
Lo-Fi Version | Time is now: 9th June 2024 - 07:05 PM |
