Some of you may have seen this "A" pillar with the tweeter boss mounted in my car before. The CF I have is cost prohibitive to reproduce.
I have held off modifying my "A" pillar mold, to include the boss, until I work out a solution for a nice OEM looking vinyl finish.
I saw a pair of Morph's speaker pods at G&R that looked like they were covered with vinyl? They looked great. Is this how Morph is selling them or someone else's nice work?
I picked up this very thin sticky back vinyl shelf paper at HD that actually looks great on flat surfaces. Just a little heat and it will couture but it is hard to control with out wrinkling.
I made a crude picture frame to vacuum the HD vinyl over the part. That helped but It looks likeI will have to make a dedicated vacuum table and frame with some heat souse to get the quality I am looking for. I have seen some 3M vinyl that seems very pricey. I am not sure if that is what the dash recover guys are using? A more proper vinyl may help.
After seeing a, complex shape, thermo formed ABS cover at work the other day I am also considering other options. An ABS with a surface finish on one side would make a nice part but with a cheaper nonOEM look.
I have also seen some kind of over lay patterns that can be put on wheels, dash, grills... This was last seen up at Pomona Auto show.
I was thinking some of you, Morph, may have connections or ideas to produce a hi quality low cost part . Your thoughts...
