> Intermittent wipers are intermittent even in the off position, Mystery Solved... Read On
tomeric914
post Jul 22 2012, 03:02 PM
One Lap of America in a 914!
So now that I have the wiper relay, the intermittent wipers are intermittent even in the off position! Not sure what is causing that. Any ideas?
Also, when I pull the wiper stalk, I hear a relay click but only when the wipers are in the intermittent position. I thought it had to do with activating the wipers while in the wash mode but I would think I'd hear a click when it was in the off mode as well. (IMG:style_emoticons/default/idea.gif)
Edit: I should have done a search first regarding the ground wire. Does anyone have a photo of where this ground wire is?
jim_hoyland
post Jul 30 2012, 09:33 AM
Get that VIN ?
Try replacing the intermittant wiperrelay with a known relay that works right. I had one situation where I got ghost wipes when the wipers were off; I replaced the relay and ghost wiping went away. In another situation, the a brand new relay failed to operate properly even though the part number was the same... (IMG:style_emoticons/default/smile.gif) If there was a bench test for the intermittant wiper relay, the elimination process would be a lot easier. (IMG:style_emoticons/default/dry.gif)
tomeric914   Intermittent wipers are intermittent even in the off position   Jul 22 2012, 03:02 PM
tomeric914   Does anyone have pictures of the steering column w...   Jul 30 2012, 08:05 AM
jim_hoyland   Try replacing the intermittant wiperrelay with a k...   Jul 30 2012, 09:33 AM
tomeric914   Try replacing the intermittent wiper relay with a...   Jul 30 2012, 09:49 AM
Bartlett 914   I have seen where the wiper switch isn't groun...   Jul 30 2012, 04:23 PM
76-914   check the brn/wht wire connection at the relay(in...   Jul 30 2012, 06:40 PM
tomeric914   check the brn/wht wire connection at the relay(i...   Jul 30 2012, 09:37 PM
tomeric914   Alright, I guess I have to take my own pictures. ...   Jul 30 2012, 09:28 PM
partwerks   All my ghost wipe was attributed to was one of the...   Jul 30 2012, 09:45 PM
tomeric914   Found more info, pictures, and video including wir...   Jul 31 2012, 02:23 PM
Valy   This is what I have on my car. I like it since it ...   Jul 31 2012, 03:58 PM
tomeric914   I needed pictures of a good known switch for what ...   Jul 31 2012, 06:50 PM
Cupomeat   Its like flying in clouds, You can't see the g...   Jul 31 2012, 07:23 PM
markb   I wish you would have said something a couple of d...   Jul 31 2012, 07:27 PM
tomeric914   Damn, I suppose you could fabricate it. Thought ...   Jul 31 2012, 08:24 PM
r_towle   I don't see a problem, they are either intermi...   Jul 31 2012, 08:35 PM
mrbubblehead   how funny, i just did this mod. valy posted up the...   Aug 1 2012, 06:55 PM
Eric_Shea   When I was working on my switch applications, I fe...   Aug 2 2012, 07:01 AM
tomeric914   I know the piece dropped out on me as well, but th...   Aug 2 2012, 12:28 PM
mrbubblehead   i got my 5 wire switch out of a 75 914. and the li...   Aug 2 2012, 12:55 PM
Eric_Shea   You did exactly what I did with the 924 switch. T...   Aug 2 2012, 01:38 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 06:25 PM
