Would this work for Mid Engine setup?, 1997 Chevrolet Corvette C5 Manual 6-Speed Transmission & 3.42 LSD Differential |
falconfp2001 |
Aug 8 2012, 01:56 PM
Pancho Pantera Group: Members Posts: 451 Joined: 5-December 10 From: Downey, CA Member No.: 12,456 Region Association: Southwest Region |
I was eyeballing this and just wondering how possible is this Transmission for a mid engine setup?
http://www.ebay.com/itm/ws/eBayISAPI.dll?V...B:WNARL:US:1120 |
rktmn247 |
Aug 8 2012, 03:14 PM
Irish Green with GT envy! Group: Members Posts: 347 Joined: 18-August 05 From: Mililani, HI Member No.: 4,612 Region Association: None |
Should there also be a bell housing? If so, It looks like axles would be way to far back.
ThePaintedMan |
Aug 8 2012, 03:21 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Should there also be a bell housing? If so, It looks like axles would be way to far back. No, the C5 and up Vettes use a torque tube that houses the driveshaft and bolts between engine and transaxle. I think there are adapters to bolt the engine directly to the transaxle, but I would assume that this would put everything way far back. You would probably end up cutting the rear firewall and moving it forward to fit. Not to mention that transaxle is really beefy and heavy. Doubt it would be worth the trouble. |
rktmn247 |
Aug 9 2012, 12:15 AM
Should there also be a bell housing? If so, It looks like axles would be way to far back. No, the C5 and up Vettes use a torque tube that houses the driveshaft and bolts between engine and transaxle. I think there are adapters to bolt the engine directly to the transaxle, but I would assume that this would put everything way far back. You would probably end up cutting the rear firewall and moving it forward to fit. Not to mention that transaxle is really beefy and heavy. Doubt it would be worth the trouble. I know they use a torque tube and assumed there is a housing attached on the block for the clutch and pressure plate that would have to be connected back up to the transaxle, minus the torque tube, thus increasing the length beyond what the original poster had shown in his link. http://www.ebay.com/itm/1997-Chevrolet-Cor...#ht_2460wt_1218 |
Lo-Fi Version | Time is now: 8th June 2024 - 03:20 PM |
