Vapor lock? |
Vapor lock? |
mrholland2 |
Aug 13 2012, 09:21 PM
Senior Member Group: Members Posts: 753 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
Okay, first off-I have driven my car with a partial tank of gas with it hotter than today. (Electric fuel pump--fairly new. . single carb)
Today at about 5:15 pm, I filled the tank, drove 10 miles and stopped to get the mail. Re started the car and drove 10 feet. . it died. Managed to get it to off and on to sort of run the 150 yards to get it home. We also have ALOT of wildfire smoke in the air. Thoughts and suggestions? |
Dave_Darling |
Aug 13 2012, 10:32 PM
Where is the pump located?
Did you have fuel pressure? Did you have fuel in the float bowls? Did you have power and ground to the pump? --DD |
mrholland2 |
Aug 13 2012, 10:38 PM
Where is the pump located? Did you have fuel pressure? Did you have fuel in the float bowls? Did you have power and ground to the pump? --DD The pump is located on the brace just to the rear of the battery. No, the Fuel in the bowls was burned and the car died. It has fuel now Yes, the pump works great NOW. . I'm just wanting to avoid a repeat tomorrow. . I drive the car every day I can |
Lo-Fi Version | Time is now: 10th June 2024 - 11:49 PM |
