What is the best, most cost effective fuel pump?, For Dual Carbs? |
tornik550 |
Aug 13 2012, 08:46 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I have killed a couple of carter inline fuel pumps. I am interested in getting a new low pressure fuel pump for dual carbs. What is the most cost effective and reliable system that I should get?
rhodyguy |
Aug 14 2012, 08:29 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
the canister is a fuel filter. when you do the next test leave it on. just run the fuel into a gas can with a long piece of fuel line connected after the tee and see if the flow slows down. when new, the pump/filter come with squeeze clamps that make it a pain to change. after the test toss it and try a stock fi filter installed prior to the pump.
k |
Lo-Fi Version | Time is now: 10th June 2024 - 10:51 PM |
