What is this?, Oil dripping from here |
ericoneal |
Aug 19 2012, 07:35 PM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
Hi all, new 914 owner here. Loving the car, but of course it has some oil leaks, for now. The previous owner disclosed that the pushrod tube seals were leaking (and they are!) and also the oil temperature sensor seal area.
I am also getting a few drips from the, what I think to be, the dust boot on the gear shift linkage. Total noob here, so bear with me. Could this just be blowback from the other oil leaks, which arent too bad really, or could something really be leaking from here. The attached pic is not my car, but that is where the oil is dripping from. Its just a dust boot, right? Its not really sealing anything is it? Thanks! Attached image(s) |
Dave_Darling |
Aug 20 2012, 12:28 AM
Do the drips off of that cover stink like rotten eggs? If so, then they are gear oil. You'll find more of it inside the cover. There is a seal around the gear selector which can eventually start to leak. You remove the side shift console (two nuts hold it in, but drain the fluid first!) and drive out a pin to get the shaft out, then you can replace the seal(s?).
If the drips just smell like oil, chances are better that it's blow-back from the leaks further forward. --DD |
Lo-Fi Version | Time is now: 2nd June 2024 - 06:11 PM |
