Should all injectors click when pressing throttle before starting?, I searched, I really did... |
Rockaria |
Aug 20 2012, 10:05 AM
ZippidyDoDah... Group: Members Posts: 817 Joined: 2-May 03 From: Southwest, USA Member No.: 645 Region Association: None |
Hello Everyone,
I am trying to revive a 73 2.0 from a long period of rest (5 years). I am having some troubles and have search till I can't see straight. I am in the process of trouble shooting but have one question (for now): I read that I should have 20 clicks from my injectors if I press the accelerator pedal to the floor slowly before starting. Should all 4 injectors click? Right now only injectors 1 and 4 click, 2 and 3 do nothing. BUT, if I swap the wires from 1 to 2 and from 3 to 4 I get the oposite. 2 clicks and 3 clicks but not 1 and 4. Is this normal? 73 2.0 Stock D-Jet FI. |
McMark |
Aug 20 2012, 10:40 AM
No, only the set of injectors that is being 'activated' by the trigger points. I went through that pretty recently and learned.
If you rotate the engine (and thereby the trigger points) a bit you should switch to the other bank. |
Lo-Fi Version | Time is now: 2nd June 2024 - 10:27 AM |
