Trick to getting side window seals into targa top |
hydroliftin |
Aug 20 2012, 01:20 PM
Member Group: Members Posts: 373 Joined: 8-November 06 From: Vallejo, CA Member No.: 7,180 Region Association: Northern California |
This seems like such a simple job that even I should be able to do it. I tried using soap to lubricate the rubber, and I was able to get it about 8 inches into the channel. After washing that off I tried silicone lubricant spray and was able to get the rubber a little further into the channel, but still stuck about half way. Anyone know the trick to getting these in?
SLITS |
Aug 20 2012, 01:30 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
This seems like such a simple job that even I should be able to do it. I tried using soap to lubricate the rubber, and I was able to get it about 8 inches into the channel. After washing that off I tried silicone lubricant spray and was able to get the rubber a little further into the channel, but still stuck about half way. Anyone know the trick to getting these in? Did you check the rails for staking? At times they put the rubber in and use a punch on the side of the rails to stake the rubber in place so it doesn't move. Otherwise, put one side in the channel and use a table knife or other dull instrument to lever the other side in. Alternatively, as you try to slide it in, lubricate the leading edge with a lubricant of your choice. Inserting a rod or something under the flat section breaks the suction between the flat surfaces. It can be done! |
montoya 73 2.0 |
Aug 20 2012, 04:59 PM
Lack of consideration to others, and Selfish! Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California |
Lo-Fi Version | Time is now: 10th June 2024 - 08:58 AM |
