First Look: 914-6 Alloy Rear Calipers, ...about 30 days out. |
Eric_Shea |
Aug 14 2012, 08:16 AM
PMB Performance Group: Admin Posts: 19,275 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
The time has come. We are beginning to take pre-orders on the 914-6 rear calipers.
As you know, us 914 owners have long been looking for a solution to a properly biased brake system. The fronts have been the easy part, bolt on a pair of Brembo's ...or a 3.5" 911 front suspension and you would have your choice of larger calipers with 48mm pistons up front. But, what about the rears? You need a 38mm piston to give you the correct bias. For 914 owners that meant a long and winding road of searching for the proper solution which usually boiled down to two things; uber-rare (and uber-expensive) original 914-6 calipers or 911 rear calipers and a confusing handbrake assembly or, worse yet, 911 rear calipers and no handbrake solution. Well, you're looking at the true bolt on solution. Aluminum castings of the famous 914-6 rear calipers. Final weigh-in has yet to be established but, we think we'll be under 3lbs each with the aluminum pistons. These simply bolt on and use stock handbrake cables and parts. Larger pistons and larger pads make this the prefect rear caliper solution for Brembo bolt-ons and S-Caliper or A-Caliper upgrades. What you are looking at is a raw alloy assembled prototype prior to anodizing. (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-b.xx.fbcdn.net-1110-1344953789.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-b.xx.fbcdn.net-1110-1344953790.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-a.xx.fbcdn.net-1110-1344953790.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-b.xx.fbcdn.net-1110-1344953791.4.jpg) |
Eric_Shea |
Aug 20 2012, 06:29 PM
The Brembo's will work on 914 struts in two configurations:
1. Without the spacers on an "early" 914 strut and a solid rotor. 2. With the BRAG hub that Mike Mueller designed for Brad Roberts, on a late strut and a vented rotor. Regardless, I would move to a 3" 911 Boge strut and have the 911 hub, vented rotors and beefier bearings. Not that 914 bearings have been problematic... it's just that the BRAG hubs are NLA and as expensive or more expensive than a nice set of 3" 911 struts. I think machining the calipers would be good money for bad. |
gothspeed |
Aug 20 2012, 07:22 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
The Brembo's will work on 914 struts in two configurations: 1. Without the spacers on an "early" 914 strut and a solid rotor. 2. With the BRAG hub that Mike Mueller designed for Brad Roberts, on a late strut and a vented rotor. Regardless, I would move to a 3" 911 Boge strut and have the 911 hub, vented rotors and beefier bearings. Not that 914 bearings have been problematic... it's just that the BRAG hubs are NLA and as expensive or more expensive than a nice set of 3" 911 struts. I think machining the calipers would be good money for bad. If you do not offer the machining ....... then ...... if I were to send you my pair of steel 1968 ATE 'M' calipers already machined at the mounting flange, would you be able to rebuild them? Maybe I can search for someone with a larger mill ... When I get some other projects out of the way, I was thinking of making some of those NLA alloy hubs for late 914 struts. Because everytime I go looking for 911 struts I end up wasting a ton of time trying to find and identify years etc.. I always have the worst luck when it comes model compatability and fitment (IMG:style_emoticons/default/unsure.gif) |
Lo-Fi Version | Time is now: 28th May 2024 - 08:32 PM |
