ss6 |
fun city... ![]() ![]() Group: Members Posts: 261 Joined: 2-February 03 From: Western Connecticut Member No.: 221 ![]() |
I occasionally get the old grinding gear noise (usually into 1st or reverse), and 3rd sometimes doesn't want to drop in too easily. Tranny was "freshened" about 3000 mi ago.
I replaced the clutch, throwout bearing, and cable when I took the tranny out. What is a little weird is the cable adjustment is all the way up the threaded rod despite all this new stuff. Am wondering if the shifting issues are related. I've seen references to needing to "jack up" the clutch lever fulcrum with a washer. When I had the tranny rebuilt, I put it back in the way it came out, ie no washer. Anybody have any experience in this area? Adding the washer means dropping the !@#$ tranny again, and CV joint grease is not my favorite hair gel, even if it does hide the gray. |
TonyAKAVW |
That's my ride. ![]() ![]() ![]() ![]() Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None ![]() |
I am just in the process of researching things needed to do a 1st gear synchro repair and clutch job. From what I have read, the plastic bushing at the throwout fulcrom ball joint often needs replacement. I'm not sure if this would help things but I can imagine that if its worn down it coule cause problems. I saw one just the other day in a car that was broken and destroyed. I think Pelican sells this part for less than $5 or so.
-Tony |
Lo-Fi Version | Time is now: 12th July 2025 - 03:08 PM |
