V8 Conversion Alternator, Any specific year required? |
Mike T |
Jun 6 2004, 09:26 PM
can't 'member Group: Members Posts: 378 Joined: 16-January 03 From: Brackney, PA Member No.: 161 |
I just installed the alternator on my conversion and was forced to space out the mounting bracket 1/2" to get the pulleys to line up. I'm using the Desert Hybrids balancer and mount which look similar to old RSH design. I've looked at plenty of pics and can't tell if anyone else used spacers. If the pulley on the alternator stuck out 1/2" more it would work. The alternator I'm using is from a 1984 Chevy truck w/V8 engine.
Is there a specific unit that I should be using? Mike T Attached image(s) |
skline |
Jun 8 2004, 07:27 AM
Born to Drive Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California |
I am using the one wire alternator but any should work. When you installed the harmonic balancer, did you use the spacer that does behind it? There is a spacer to put behind the balancer because the HB is from a Chevy 6 cylinder engine. If you put the motor together, you would remember it.
Lo-Fi Version | Time is now: 6th June 2024 - 05:06 AM |
