| thompson-mfr |
Aug 29 2012, 02:08 PM
Thompson, Ryan ![]() ![]() Group: Members Posts: 198 Joined: 30-September 08 From: Silverton, OR Member No.: 9,598 Region Association: Pacific Northwest |
Ok, I will try and keep this as brief as I can.
I will pose the question before providing the background. ?? What, if any, effect does the MPS have to do with actual timing of the motor?? Now for the reason for my question. 1974 2.0L FI My MPS (0 280 100 019 adjusted VW T4 unit) randomly stopped working properly even though electrically it checks out and holds vacuum. Maybe an aneroid cell? anyway not sure. I then started trouble shooting thinking it was points, plug wires, etc. ( I replaced to be sure) and readjusted the timing and dwel. Right after the MPS stopped working I found a good deal on another nice '74 2.0 FI 914. It has a factory MPS correct PN 0280 100 043 and runs perfectly. So, I thought I would swap MPS's and see if this fixed my problem. It didn't run well. Thoughts?? I have read Pbanders a bunch of times. I have included a picture of the new car in hopes there are others like me that like pictures. I only open threads with pictures as I cannot read good (well )just joking). Maybe other people can relate to this. |
| brant |
Aug 29 2012, 03:51 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,150 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
I'm sorry I was talking about a wideband 02 sensor
perhaps there is someone in Oregon that will loan one to you or help out for 30 minutes and the price of a beer On the wideband, I could see where an 8th turn of the screw was the difference between way too rich and way too lean its a really really sensitive adjustment, and there are 2 seperate adjusments (2 screws) brant |
| thompson-mfr |
Aug 29 2012, 04:50 PM
I'm sorry I was talking about a wideband 02 sensor perhaps there is someone in Oregon that will loan one to you or help out for 30 minutes and the price of a beer On the wideband, I could see where an 8th turn of the screw was the difference between way too rich and way too lean its a really really sensitive adjustment, and there are 2 seperate adjusments (2 screws) brant yeah, I have attempted to adjust the 019 T4 MPS the same as the good 043 MPS with an LCR meter and it cannot match. The internals of the T4 MPS must be a little different. I have heard this from other sources. Do you use an in cockpit one or a meter style. Maybe I need to breakdown and spend the $$$. I have seen them for $170 and then the cost of an o2 sensor. Does this seem right? |
thompson-mfr Manifold Pressure Sensor MPS and timing Aug 29 2012, 02:08 PM
SLITS MPS has no effect on engine timing.
It only deter... Aug 29 2012, 02:12 PM
ThinAir Since you were running a non-stock, adjusted, MPS ... Aug 29 2012, 02:21 PM
thompson-mfr
Since you were running a non-stock, adjusted, MPS... Aug 29 2012, 02:50 PM
brant I hope your using a wideband o2 sensor to adjust t... Aug 29 2012, 02:58 PM
thompson-mfr
I hope your using a wideband o2 sensor to adjust ... Aug 29 2012, 03:48 PM
SLITS For $3 off the net from China, you can buy a ... Aug 29 2012, 04:15 PM
thompson-mfr
For $3 off the net from China, you can buy a... Aug 29 2012, 04:57 PM
SLITS
For $3 off the net from China, you can buy ... Aug 29 2012, 05:15 PM
Dave_Darling
For $3 off the net from China, you can buy a... Aug 29 2012, 11:50 PM
Krieger You can buy a cheap a/f meter from JEGS for ... Aug 29 2012, 07:01 PM
Bleyseng If you plugged in a stock 043 MPS into a 74 2.0l F... Aug 30 2012, 07:52 AM
thompson-mfr
If you plugged in a stock 043 MPS into a 74 2.0l ... Aug 30 2012, 08:49 AM
SLITS
I find it very strange the factory 043 MPS does n... Aug 30 2012, 08:53 AM
thompson-mfr
I find it very strange the factory 043 MPS does ... Aug 30 2012, 09:02 AM![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 12:28 AM |
