kbrunk1 |
Brunk ![]() ![]() Group: Members Posts: 180 Joined: 13-November 11 From: Dallas,Texas 73 2.0 FI Member No.: 13,778 Region Association: South East States ![]() |
Do you have to use the $12 each Fuel Injector Line Elbow's
What happens if you just use fuel line? Are folks buying 8mm fuel line? Where? Thanks |
pilothyer |
Member ![]() ![]() ![]() Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States ![]() |
Another "point to ponder" is, Can you get the new elbows in the newer "Flex Fuel" grade for Ethanol mix fuel ??????? If not you may have to skip the preformed elbows.
Bartlett 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest ![]() |
Another "point to ponder" is, Can you get the new elbows in the newer "Flex Fuel" grade for Ethanol mix fuel ??????? If not you may have to skip the preformed elbows. Good point (IMG:style_emoticons/default/popcorn[1].gif) Biggest problem I see is in dropping the engine. Without the elbows, they will get hung up in the engine shelf. You have to be extra careful when dropping the engine. |
Lo-Fi Version | Time is now: 8th July 2025 - 09:23 PM |
