> Stock Fuel pump 1973 2.0, How mounted?
Jesco Reient
post Sep 1 2012, 10:36 AM
This 914 has been mistreated to different respects in it's former life and currently I am fixing a lot of that. I have installed the SS fuel line kit from Tangerine Racing, and have cleaned the tank and replaced all the fuel lines with the latest greatest ethanol happy compound. The fuel pump slips into the bracket on the firewall, does the wire connector face down, or towards the rear? Also are there any seals inside that will be damaged if I disassemble the pump for a rebuild?
type47
post Sep 1 2012, 08:31 PM
Viermeister
I think the connector faces down based on what I remember from the workshop manual pictures. The FP has an o-ring under the "face" that you would remove is you took out the bolts. There are some little rollers that you'd want to make sure you didn't lose if you took it apart. I'd have a replacement o-ring in hand if I took it apart, if it were me......problem is finding a replacement o-ring....
- Lo-Fi Version Time is now: 21st August 2025 - 08:06 AM
