| sfrenck |
Sep 2 2012, 12:15 PM
Member ![]() ![]() Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region
PO relocated my 74 3-port fuel pump to the rear fire wall to the right of the the speedo cable, fuel lines, flapper wires, etc.
![]() ![]() I've got the fuel tank out to replace the fuel lines with SS ones now, but I don't want to relocate the fuel pump up front if I don't have to (don't like it being below the steering rack). Is this location far enough away from the HE's to avoid problems? |
| TheCabinetmaker |
Sep 2 2012, 01:51 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,358 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I can't see why it would not be fine there if its not too high. At least the flapper is not dumping the heat directly on it like the stock location. Id leave it till i had a problem.
sfrenck 74 Fuel Pump - Relocated, but to an OK spot? Sep 2 2012, 12:15 PM
kg6dxn You may create problems with the pump there. The f... Sep 2 2012, 01:32 PM
sfrenck
You may create problems with the pump there. The ... Sep 2 2012, 01:41 PM
tim_nd It's really not that much work moving it to th... Sep 2 2012, 02:42 PM
sfrenck
It's really not that much work moving it to t... Sep 2 2012, 02:54 PM
mittelmotor Another option is to mount the pump beneath the ta... Sep 2 2012, 07:17 PM
rhodyguy i mounted mine in approx the same position. no pro... Sep 3 2012, 01:18 PM
sfrenck
i mounted mine in approx the same position. no pr... Sep 3 2012, 02:02 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th December 2025 - 09:04 PM |
