| sfrenck |
Sep 2 2012, 12:15 PM
Member ![]() ![]() Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region
PO relocated my 74 3-port fuel pump to the rear fire wall to the right of the the speedo cable, fuel lines, flapper wires, etc.
![]() ![]() I've got the fuel tank out to replace the fuel lines with SS ones now, but I don't want to relocate the fuel pump up front if I don't have to (don't like it being below the steering rack). Is this location far enough away from the HE's to avoid problems? |
| mittelmotor |
Sep 2 2012, 07:17 PM
Member ![]() ![]() Group: Members Posts: 334 Joined: 21-May 12 From: SoCal Member No.: 14,464 Region Association: None |
Another option is to mount the pump beneath the tank, just forward of the reservoir brake lines. Plenty of space, just make sure it's mounted low enough to clear the anti-roll bar, if your car has one.
The downside is access, but the pumps are reliable, and pulling the tank is not that difficult. Just make sure all your hose connections are solid (I double-clamped everything on the high pressure side of the pump). Attached thumbnail(s) |
sfrenck 74 Fuel Pump - Relocated, but to an OK spot? Sep 2 2012, 12:15 PM
kg6dxn You may create problems with the pump there. The f... Sep 2 2012, 01:32 PM
sfrenck
You may create problems with the pump there. The ... Sep 2 2012, 01:41 PM
The Cabinetmaker I can't see why it would not be fine there if ... Sep 2 2012, 01:51 PM
tim_nd It's really not that much work moving it to th... Sep 2 2012, 02:42 PM
sfrenck
It's really not that much work moving it to t... Sep 2 2012, 02:54 PM
rhodyguy i mounted mine in approx the same position. no pro... Sep 3 2012, 01:18 PM
sfrenck
i mounted mine in approx the same position. no pr... Sep 3 2012, 02:02 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th December 2025 - 09:04 PM |
