WTB: Stock sachs/boge lower spring perches, (or even full stock shock/spring assemblies) |
r3dplanet |
Sep 1 2012, 11:31 AM
Senior Member Group: Members Posts: 679 Joined: 3-September 05 From: Portland, Oregon Member No.: 4,741 Region Association: None |
I'm removing a very not-at-all-stock rear shock setup. I bought a set of 100lb springs and Sachs/Boge shocks. When I went to install them I find that there's no way to connect the spring to the lower part of the shock.
So apparently there's a perch or mount and some rubber pieces in stock setups. I need to get my hands on a good set. Optionally, if anyone has a complete stock shock/spring assembly I'd be willing to buy them so I can do the disassembly myself. Anyone have a nice pair? Thanks, Marcus |
r3dplanet |
Sep 4 2012, 07:49 PM
Well, thanks for looking anyway. I appreciate you taking the time to look.
It turns out that my tops are just fine. It's just the lower cups that I need. Still available new, yes. For $133-$150 each. That's way more than a whole new set of Bilsteins cost. I would have guessed with all the Koni and Bilstein replacements over the years these perches would be kicking around many a garage. |
bdstone914 |
Sep 5 2012, 10:14 AM
bdstone914 Group: Members Posts: 4,538 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I should have some BOGE lower perches. Those pictured above are not correct for BOGE shocks. If I have a pair from bad shocks they will be $25 for the pair to cover the time and cost to pull them.
They were available from Porsche last time I checked for about $136 each. Bruce |
Lo-Fi Version | Time is now: 11th June 2024 - 09:27 AM |
