| Tom |
Sep 7 2012, 11:48 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Looks like I screwed up. While I had the trailing arms off, I removed the axles to check them out. (IMG:style_emoticons/default/sad.gif) Thought I would leave them off until I got the trailing arm back on. I am doing this by myself and didn't think I would be able to align the axle, shock bolt and front of the trailing arm all at once to get it on.
Put the trailing arm back on and now the axle won't fit without removing the heat exchangers. They don't leak, so I do not want to mess with them. Don't want to remove the trailing arm either. I may have to do one or the other unless someone with more experience can straighten me out on this. Is it possible to loosen the trans supports and drop the trans/engine a couple of inches to allow one end of the axle room to go over the top of the trans and allow the other end into the trailing arm? Thanks, Tom |
| Tom |
Sep 7 2012, 05:50 PM
Thanks guys, I will try lowering the trans a bit and sliding in the outer end first on both sides, then proceed.
John, I tried every which way to get the shaft in without lowering the trans, but I still was lacking a couple ( or more) of inches of clearance. Tomorrow I will try lowering the rear of the trans and see how that works. Thanks, Tom |
| 76-914 |
Sep 7 2012, 10:01 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,993 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Thanks guys, I will try lowering the trans a bit and sliding in the outer end first on both sides, then proceed. John, I tried every which way to get the shaft in without lowering the trans, but I still was lacking a couple ( or more) of inches of clearance. Tomorrow I will try lowering the rear of the trans and see how that works. Thanks, Tom I should have mentioned this earlier. Put a floor jack under your tranny and drop the rear mounts. Then you can sway the tranny to the side but I'm sure it stress's the front mounts a little. Have you already tried to disconnect the shock? |
Tom Axle question Sep 7 2012, 11:48 AM
tim_nd :confused:
I'm having a hard time following ... Sep 7 2012, 12:50 PM
914itis It's a Pita but can be done . You don't ha... Sep 7 2012, 01:15 PM
76-914 Tom, usually the passenger side will go on but the... Sep 7 2012, 01:47 PM
rdauenhauer :agree:
Just so happens I just did this ..in reve... Sep 7 2012, 01:52 PM
john rogers If the axle is complete it is a tad tighter but wi... Sep 7 2012, 04:35 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd November 2026 - 02:03 AM |
