tranny woes, help me figure this out tranny woes |
webrocket |
Sep 15 2012, 04:23 PM
Newbie Group: Members Posts: 12 Joined: 23-June 12 From: azusa, ca Member No.: 14,595 Region Association: Southern California |
HAVE A 1970 1.7 HAVE REPLACED BUSHINGS, BALLS, CUP, AND SEEMS TO NOT HAVE A FIRST GEAR OR TAKES ALOT OF PEDAL TO GET IT MOVING . APPEARS TO GO IN REVERSE AND IT APPEARS TO GO IN FIRST YET TAKES ALOT OF PEDAL MOVEMENT AND REVING TO MAKE HER GO. CAN IT BE LINKAGE, MOTOR, ANYBODY GOT A CLUE SO CAL AZUSA
toolguy |
Sep 15 2012, 05:07 PM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
Sounds like the clutch is draging. . .
The #1 trouble is the bosen tube the clutch cable runs through is loose in the tunnel. . it has welds in 2 places that break. . . and in the last of it's life it pulls through the firewall. . . very common trouble. . . remove the shifter so you can see the tube in the tunnel. . step on the clutch and see if it moves. . there should be NO MOVEMENT of the tube. |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:13 PM |
