Gas tank resealing/ child labor laws, New question: Exterior paint |
Krieger |
Sep 9 2012, 02:37 PM
Advanced Member Group: Members Posts: 4,728 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
My 10 yo helped me clean the inside of the tank. I had a lightly rusted area about 2"x 2" that came off easily. Should I coat this tank or just leave it bare?
Attached thumbnail(s) |
worn |
Sep 12 2012, 01:41 PM
can't remember Group: Members Posts: 3,164 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
My 10 yo helped me clean the inside of the tank. I had a lightly rusted area about 2"x 2" that came off easily. Should I coat this tank or just leave it bare? Here is what I do. The tank in the photo is for a TR6, but I did the same for a badly rusted 914 tank. I used evaporust for a week at about 100 degrees F, and then a couple of days with a mix of nuts, bolts, chain and WD-40 cycling around in this contraption. Shafts tack welded to flange on tank. LOUD. (IMG:style_emoticons/default/happy11.gif) |
Elliot Cannon |
Sep 12 2012, 09:50 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
My 10 yo helped me clean the inside of the tank. I had a lightly rusted area about 2"x 2" that came off easily. Should I coat this tank or just leave it bare? Here is what I do. The tank in the photo is for a TR6, but I did the same for a badly rusted 914 tank. I used evaporust for a week at about 100 degrees F, and then a couple of days with a mix of nuts, bolts, chain and WD-40 cycling around in this contraption. Shafts tack welded to flange on tank. LOUD. (IMG:style_emoticons/default/happy11.gif) And when you're not cleaning a tank with it, you can roast a pig or something. (IMG:style_emoticons/default/av-943.gif) Yankee ingenuity at it's best. |
Strudelwagon |
Sep 16 2012, 10:58 AM
Member Group: Members Posts: 411 Joined: 11-October 08 From: interior, British Columbia Member No.: 9,633 Region Association: Canada |
My 10 yo helped me clean the inside of the tank. I had a lightly rusted area about 2"x 2" that came off easily. Should I coat this tank or just leave it bare? Here is what I do. The tank in the photo is for a TR6, but I did the same for a badly rusted 914 tank. I used evaporust for a week at about 100 degrees F, and then a couple of days with a mix of nuts, bolts, chain and WD-40 cycling around in this contraption. Shafts tack welded to flange on tank. LOUD. (IMG:style_emoticons/default/happy11.gif) And when you're not cleaning a tank with it, you can roast a pig or something. (IMG:style_emoticons/default/av-943.gif) Yankee ingenuity at it's best. I see some design flaws for its use as a pig roaster! (IMG:style_emoticons/default/happy11.gif) SW |
Lo-Fi Version | Time is now: 10th June 2024 - 04:46 PM |
