| Tom |
Aug 18 2011, 10:32 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
What do you guys think? Good enough to get the car to the alignment shop?
| Tom |
Sep 16 2012, 04:23 PM
Well, things did not go as well as I was hoping. I thought the axles would go in with the trailing arm on. No! One must either have the trailing arm off or the exhaust system off. My exhaust doesn't leak, so I am going to leave it alone.
Also decided that while the axles are off, since they are somewhat a pain to remove and install, I might as well service the CV's. The rubber boots are looking old and cracked so I ordered new ones. Now to clean and service the CV's. One axle done and ready for new grease and boots. I plan on sandblasting the axle and paint it before reassembly. I was surprised at how easy the cv went back together. I did review the proper way to get the balls in before trying and it worked very well. I am beginning to see why the designers made the trunks on 914's so large - they make a great storage place for parts! (IMG:style_emoticons/default/smile.gif) At this rate, I will have this car ready for spring. (IMG:style_emoticons/default/biggrin.gif) The trailing arm installed and greased moved up and down by hand easily prior to hooking up the shock. That Eric sure does nice work! Tom Attached thumbnail(s) |
Tom Trailing arm alignment Aug 18 2011, 10:32 AM
Dave_Darling Should be, if your pen lines are reasonably close ... Aug 18 2011, 10:46 AM
Ductech If you are going thru with doing any kinda measure... Aug 18 2011, 10:58 AM
PeeGreen 914 Tom,
Are you going to have Tim realign this and a... Aug 18 2011, 11:06 AM
Tom Jon,
Yes, I will get Tim to do the alignment l... Aug 18 2011, 11:11 AM
PeeGreen 914 Well in that case I would just grab the rear of th... Aug 18 2011, 11:12 AM
r_towle the real question is how far is the alignment shop... Aug 18 2011, 01:15 PM
Tom Well, fast forward a year and I am finally getting... Sep 7 2012, 10:14 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:10 PM |
