Low idle at operating temp |
moneysmarts |
Jun 9 2004, 05:33 PM
Member Group: Members Posts: 164 Joined: 2-March 04 From: Central Massachusetts Member No.: 1,745 Region Association: None |
74 2.0. When I get up to operating temperature, the idle drops down below 1K and frequently stalls.
I need to backed out the adjustment screw, nearly all the way (until it starts to hiss at a really loud pitch) in order to get the idle up to 900-1000. This can't be the solution. Any ideas? Thanks in advance. |
Bleyseng |
Jun 9 2004, 09:02 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
If you need to back out the idle air bypass screw nearly all the way, the timing is off. It has to be set correctly at 27 degrees BTDC @3500 rpms with hoses off.
Setting a good idle is: Valves adjusted timing adjusted hoses installed correctly adjust air bypass and ECU when the motor is hot. Geoff |
Lo-Fi Version | Time is now: 8th June 2024 - 02:16 AM |
