Installed Wiring Harness Today |
mikey |
Jun 9 2004, 02:21 AM
Member Group: Members Posts: 423 Joined: 30-January 03 From: San Francisco Member No.: 214 Region Association: None |
I thought I'd post this to save some other poor soul the same grief that I just went through. I installed a brand new wiring harness (well the back half anyway) into my 914-6 today. It's not easy but one person can do it.
I found out the hard way that everything, including connectors, has to fit through a quarter size hole just after exiting the firewall. The connector for the relay board had to go through this hole first because it won't fit with anything else in this hole - I mean even a single wire already in this hole would make the fit too tight for the relay board connector to pass through. Then I started feeding other wires through. I ran into a round connector that I thought wasn't going to make it through undamaged but with a little persuasion it finally worked. Oh, and another thing...the back end of the harness has to be inserted at the very front of the tunnel. It lays on top of the tunnel until it reaches midway where it passes into the tunnel, out and back in again before going through the firewall. Hope this helps somebody. (Shoulda taken some pictures) (IMG:style_emoticons/default/headbang.gif) |
mikey |
Jun 9 2004, 10:29 PM
Ken, Thanks for the tip on massaging and bending the wires into place. I got the front of the harness into the front trunk ok, but the bundle of wires under where the dash goes will be challenging. It would be helpful to have another -6 around to look under the dash.
Does anyone know where can we find the black plack protectors that fit on the tabs that hold the harness in place? Brad suggested heat shrink tubing from an electronic store, but they're a metric size. The 1/4 inch ones are just a tad too small and the next larger size is much too big. |
Lo-Fi Version | Time is now: 7th June 2024 - 08:10 PM |
