Headlight switch ooginess |
mrholland2 |
Sep 23 2012, 06:40 PM
Senior Member Group: Members Posts: 753 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
YAY: I can use headlights without blowing fuses. .. and the horn also now goes "Merrrrp merrrrp" (kind of like a European See-And-Say)
HOWEVER, When the car is OFF the key is OFF and I (accidentally) engage the RIGHT turn signal, the RIGHT park and tail lights come on. . and (I think) the same with the LEFT. Also, the headlights would not work with the wires hooked to the proper locations (according to a thread on here). I'm wondering if my switch is "ker-flooey" and needs replacement? Or do I have the only 914 that was worked over by Lucas Electrical? Sean |
jim_hoyland |
Sep 24 2012, 09:21 AM
Get that VIN ? Group: Members Posts: 9,328 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Try this for 11 pin:
30 Smaller Red From fuse #10 which is linked to #11 and #12 green w/blk trace 30B Headlight Motors Retract grey w/blk trace 58L Left Parking lights grey w/red trace 56R Rt Parking Lights grey w/yellow trace K License / Luggage lights white w/green trace 57 Park light indicator light 15 Thicker Red From "X" terminal on Ignition switch grey 56K Headlight Motor Switch Extend red w/white trace 56 Headlight motors black w/blue trace 56 To Fog light switch Attached image(s) |
mrholland2 |
Sep 24 2012, 10:47 AM
I have the 11 pin switch, but my car is a '73. . will things be different?
Thanks for your help! Sean Try this for 11 pin: 30 Smaller Red From fuse #10 which is linked to #11 and #12 green w/blk trace 30B Headlight Motors Retract grey w/blk trace 58L Left Parking lights grey w/red trace 56R Rt Parking Lights grey w/yellow trace K License / Luggage lights white w/green trace 57 Park light indicator light 15 Thicker Red From "X" terminal on Ignition switch grey 56K Headlight Motor Switch Extend red w/white trace 56 Headlight motors black w/blue trace 56 To Fog light switch |
Lo-Fi Version | Time is now: 17th June 2024 - 12:22 AM |
