jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,328 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
I'm assuming some of the tin around the oil filter will have to be removed to install a sandwich oil filter adapter and hoses for the remote cooler. Will this have a permanent effect on the passenger side heating ?
Joe Owensby |
JoeO ![]() ![]() ![]() Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States ![]() |
It can be done without modifying the tin. I have the oil cooler over the right drive shaft. I drilled two holes in the tin, and routed the hoses up through the tin, over the top right side of the engine, and then through the rear vertical tin. This keeps the hoses clear of the valve covers, and makes adjusting the valves easier. I think I posted photos somewhere on this site. JoeO
jim_hoyland |
It can be done without modifying the tin. I have the oil cooler over the right drive shaft. I drilled two holes in the tin, and routed the hoses up through the tin, over the top right side of the engine, and then through the rear vertical tin. This keeps the hoses clear of the valve covers, and makes adjusting the valves easier. I think I posted photos somewhere on this site. JoeO I lke that, and, will search for the thread... (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 17th June 2024 - 04:18 AM |
