tornik550 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None ![]() |
I have tried bleedling my brakes with three different types of bleeders and I have the same issue each time. I can get all the calipers to bleed properly except the passenger rear brake. Using the hand pump type of bleeder, I have pumped the right rear brake for a very long time and I still get bubbles. It never seems to change. I wasn't sure if I had speed bleeders or not so I removed the bleeder and found it was slightly bent (probably from over tightening). I put a new bleeder in and restarted the process- no change. Any ideas? I have not seen any fluid leaks. I have not tried to drive the car yet due to some engine issues. They were rebuilt fairly recently (by me)- is it possibel that I screwed something up? Seems to me that I would see a leak somewhere if I screwed up the rebuild.
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,788 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
No mention of you know who's long tube method?
Lo-Fi Version | Time is now: 3rd September 2025 - 08:17 PM |
