jimkelly |
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region ![]() |
i don't have a compressor, so i have been looking at electric tools.
such as an electric impact wrench and body saw - here are harbor frieght examples, but i'd prefer better quality brands. it does appear that an electrci impact wrench puts out about half the torque that air does, 220lbs vs 400lbs. any suggestions??? Attached image(s) ![]() |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,736 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Jim, for what your doing and the number of times that you will use one; I'd suggest the HF sawzall that is on sale for 19.95. I have the expensive Milwaukee but when I am need a sawzall in an abusive environment (read mud, dirt or water) I will use the HF one. So far it's lasted 2 yr's on my truck so I'm pretty sure it will last a realtor much longer. The key is the blades. Buy some good Milwaukee, Ridgid or even Sears, bi-metal blades. 24 tooth should work fine. The blades that come with the HF sawzall are bi-metal, also. Only problem is, it is Chinese bi-metal and they ain't saying which two metals they use. (IMG:style_emoticons/default/av-943.gif) Seriously, their blades are crapola. Also, when using any reciprocating saw you must hold the saw firmly against the surface when cutting or the metal dances with the blade. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 8th July 2025 - 09:32 PM |
