WTB: Alternator, high output |
timothy_nd28 |
Sep 26 2012, 02:14 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
I have narrowed down the noise inside my engine, sounded like a rod bearing going out or the windage tray rubbing against a cam lobe. Good new, it was neither, ended up being my new Oreilly's alternator. Right out of the box, the key slot on the shaft was nonexistent, I should of taken it back then. However, I was in a hurry and turned a blind eye to it. (IMG:style_emoticons/default/headbang.gif) After removing the belt, I restarted the engine and all the odd noises ceased.
So since I'm playing this alternator game again, for the second time. This time, I would like to buy a 75 hi amp version. I don't need new, a good used one should be fine. It would be nice having the pulley already installed, and my plastic front shield is in bad shape too. I'm also unsure with the bolts I used mounting my alternator, they may be incorrect. |
Lo-Fi Version | Time is now: 2nd June 2024 - 03:40 PM |
