| mrholland2 |
Sep 28 2012, 05:36 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 761 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
Okay, here's the full story:
73 1.7, carbed. Square old fuel pump died. . .replaced with a round Napa one Then started acting like vapor lock, fuel pump was REALLY hot Finally wouldn't run at all. . replaced with identical fuel pump (warranty) Ran great in hot and cool weather until today (IMG:style_emoticons/default/headbang.gif) Drove 11 miles home from work (ran fine), stopped at the mail box. . exhaust smelled a teeny bit rich. Got mail. Started car. . drove 200 feet and it died and wouldn't start, acting like vapor lock. 1/2 tank of gas more a bit more. . pushed it the rest of the way home and am frustrated. So, what fuel pump SHOULD I be using??? Maybe I have procured the wrong one? (IMG:style_emoticons/default/idea.gif) Have I left any needed info out? (IMG:style_emoticons/default/confused24.gif) Thanks Sean |
| Jeffs9146 |
Sep 28 2012, 07:36 PM
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
You need to drain the tank and pull it out. Then remove the feed line nipple and pull the screen out! Look inside the tank to see if there is a lot of sludge and clean it if nessary. Then reinstall the tank with a new screen!
$14.95 at Tangerine Racing |
mrholland2 AGAIN with the not running. Sep 28 2012, 05:36 PM
wndsrfr I'm going to bet on the screen in the fuel tan... Sep 28 2012, 05:39 PM
mrholland2 And how does this get fixed?
Are there instructio... Sep 28 2012, 05:44 PM
76-914 You might be able to do it from below after removi... Sep 28 2012, 07:37 PM
Bob L. I think I might check the fuel filter(s) first. ... Sep 28 2012, 07:56 PM
mrholland2
I think I might check the fuel filter(s) first. ... Sep 29 2012, 12:10 AM
SirAndy I think I might check the fuel filter(s) first. ... Sep 29 2012, 12:26 PM
mrholland2
[quote name='mrholland2' post='1745943' date='Sep... Sep 29 2012, 05:15 PM
bandjoey Just did this. If it's fuel, then take off th... Sep 28 2012, 08:22 PM
mrholland2
Just did this. If it's fuel, then take off t... Sep 29 2012, 12:12 AM
bulitt Like they said, filter or screen. Sometimes it wi... Sep 29 2012, 05:16 AM
Nine_14 Disconnect the Fuel line from the tank Use a separ... Sep 29 2012, 06:34 AM![]() ![]() |
Lo-Fi Version | Time is now: 18th March 2026 - 06:02 PM |
