jersey914 |
Member ![]() ![]() Group: Members Posts: 161 Joined: 6-September 12 From: Marlton, NJ Member No.: 14,895 Region Association: North East States ![]() |
My turn signals do not turn off automatically after making left or right turns and I want to make the necessary repairs. Can someone refer me to a tutorial thread or explain what I need to do to fix this issue. I an guessing I have broken parts inside the steering column so if that is indeed your suspicion, I could use a referral to a parts source as well. |
eg914 |
Member ![]() ![]() Group: Members Posts: 319 Joined: 17-June 04 From: Elk Grove, CA Member No.: 2,223 Region Association: None ![]() |
Have you checked the condition of the tab on the horn/signal cancel ring on the back of the steering wheel? If this is worn or broken the signal won't cancel. If this is the problem you can get a replacement t a VW shop. Make sure you get the correct connector size on the wire,there are narrow and wide.
jersey914 |
Have you checked the condition of the tab on the horn/signal cancel ring on the back of the steering wheel? If this is worn or broken the signal won't cancel. If this is the problem you can get a replacement t a VW shop. Make sure you get the correct connector size on the wire,there are narrow and wide. I have not done anything yet, I was waiting to get some recommendations. Thanks |
Lo-Fi Version | Time is now: 20th July 2025 - 06:28 PM |
