> ended very quietly, electrical grimlins
karmanbuilt
post Sep 29 2012, 08:14 PM
Hi all, hope everyone had a good summer. Mine ended very quietly, like when you turn the key and nothing. I've gone thru this before, and know the drill. Bad ign. switch, or starter. New Bosch starter 4/12, new ignition switch 3/12. Drove most of the summer without trouble, and have heat shield on starter. Took off the starter, and had the local FLAPS check it out.....good. Ordered two (2) ign. switch from AA. Installed one, nothing. Knowing that these are cheap Chinese parts, installed the second....same thing. All I get is red (alt) light, and pump turning. Now my blower fan won't work, and I know both the fan, and pump share the same relay and fuse at the relay is good! Ground strap at trans good! Checked past posts on this problem without any sucess. What now, am I having a gray moment (IMG:style_emoticons/default/hissyfit.gif) ??
timothy_nd28
post Sep 30 2012, 06:09 PM
I should also clarify, when checking pin 1 on the 14 pin connector, you should be checking pin 1 on the connector, not the relay board
- Lo-Fi Version Time is now: 10th March 2026 - 04:02 AM
