New to me project- carb'd car, looking for the fuel pump |
7391420 |
Oct 1 2012, 08:30 AM
Member Group: Members Posts: 353 Joined: 6-August 03 From: boston, ma Member No.: 988 |
Quick question guys,
1. in looking for the fuel pump on my new project ( a 73 2.0, with dell's) I cant find the fuel pump! I'm assuming it must have been re-located to under the tank, maybe adjacent to the MC? , any other places it could be hiding? After cleaning out the old gas, putting in fresh fuel, changing the plugs and wires, I thought I would give it a try...it spins freely, but no gas...and when I click over the ignition I cant hear the pump so it's either dead, or maybe a bad relay.... -Adam |
anderssj |
Oct 1 2012, 09:52 AM
Dog is my copilot... Group: Members Posts: 1,665 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
assuming the pump is still wired through the stock wiring/relays, also check the fuse near the center of the relay plate in the engine compartment. a quick way to tell is if the heater blower fan doesn't work--no fan, no pump.
it's marked as 91 on the picture: i've had this happen even when the fuse looked good--all it takes is a little corrosion on either end of the fuse, and you've got no pump/no gas. hope this helps! |
Lo-Fi Version | Time is now: 13th June 2024 - 03:16 AM |
