| rgolia |
Aug 31 2012, 08:44 AM
GeoJoe ![]() ![]() ![]() Group: Members Posts: 720 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States
My temp gauge doesn't move. I installed a new sender and still no movement. It does move (just a little) when the ignition is turned on so it is getting power.
| rgolia |
Oct 1 2012, 01:04 PM
Did the test and the gauge works. The wire to the sender was faulty. Installed a new sender wire. Now that the gauge works, is there a way to get more fluctuation out of it. It seems to stay in the very low range regardless of driving conditions.
rgolia original temp gauge Aug 31 2012, 08:44 AM
SLITS With power on to gauge, ground the sender wire and... Aug 31 2012, 09:20 AM
rgolia I will try that test...thanks. The original 3 po... Aug 31 2012, 11:35 AM
damesandhotrods
Did the test and the gauge works. The wire to th... Oct 1 2012, 02:25 PM
tim_nd you could lean out your motor Oct 1 2012, 01:12 PM
76-914 are your sender and gage a matched pair. look on t... Oct 1 2012, 03:45 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th April 2026 - 09:02 AM |
