Center Console Wiring Harnesses, Any interest in new hand made ones? (may turn into GB) |
A&PGirl |
Oct 2 2012, 11:20 AM
Senior Member Group: Members Posts: 1,019 Joined: 4-January 06 From: Oklahoma Member No.: 5,367 Region Association: None |
I'm curious if there is any interest in any hand made color matched 914 Center Console Wiring Harnesses p/n 914 612 151 10.
The wiring harnesses are NLA from the factory and the existing ones are in bad shape. I know a lot of people like to add them to their cars or wish for a better condition harness. The wiring harnesses would come with bigger gauge wire so it would not be a problem to put LED's in the existing bulb sockets. I would be willing to do a small number to end this year. AutoAtlanta charges $145 for a "refurbished" harness. What price would you be willing to pay for this? Highlights: Bigger gauge wire All copper wire Color matched plastic cover Matched color casing (off my example) Soldered connections Optional New Bulb Sockets The little black plug housing is NLA and you would have to do without. The black plug housing just makes it look more German. Pictures: Original New: (have everything just ran out of good solder (IMG:style_emoticons/default/biggrin.gif) ) |
A&PGirl |
Oct 2 2012, 03:39 PM
It's is not complete either. I am sitting here with a '74 1.8 harness and looking at the picture.
The volt temp branch has: Black w/blue, Red w/white and Brown. The clock branch has: Black, Brown and Black w/blue. The oil temp branch has: Black w/blue, Red w/white, Brown and Green w/Black. His harness? Nothing in the picture matches. Hell, are even the wires the right length? (IMG:style_emoticons/default/WTF.gif) The bottom line his harness is will not work because it is wrong at the core and he calls it a plug & play solution. How can it be plug & play when the oil temp branch isn't wired correctly? So spend $38 + shipping with him from something that will not work or pay $145 to AutoAtlanta for a refurbished harness. Or I would be more than to make something up for a member here that will work and is correct or I suspect at less 3 other members could do the same thing. Cold hard reality. I am a little incensed that pictures of my work is rated as not nearly as good as this guy's. (IMG:style_emoticons/default/mad.gif) (IMG:style_emoticons/default/mad.gif) Yes, you poked the damn dragon. (IMG:style_emoticons/default/mad.gif) (IMG:style_emoticons/default/type.gif) |
Lennies914 |
Oct 2 2012, 04:45 PM
Slacker Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
Yes, you poked the damn dragon. (IMG:style_emoticons/default/mad.gif) (IMG:style_emoticons/default/type.gif) [/quote] (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 12th June 2024 - 12:55 AM |
