jack point rust, Weld or replace? |
Brandon113 |
Oct 2 2012, 04:33 PM
Newbie Group: Members Posts: 10 Joined: 17-August 12 From: Bedford, Texas Member No.: 14,818 Region Association: Southwest Region |
(IMG:style_emoticons/default/hissyfit.gif) This is the only rust I have found on the longs both sides are the same think I can just cut out the rust weld a plate in and then weld the jack plate and tube in? What do you all think the metal does clean up but the rust is way more than surface. One more think what are you folks treating the inside of the longs with that won't hurt the heater tubes......
Thanks Brandon Attached thumbnail(s) |
two-strokejohn |
Oct 2 2012, 05:48 PM
Member Group: Members Posts: 81 Joined: 30-March 06 From: Orient, Ohio Member No.: 5,793 Region Association: North East States |
I think upon closer inspection inside the long, you'll find more rust that should be repaired. If you let this go.... it can only get worse............ us east coast people can tell you horror stories about these areas.
Lo-Fi Version | Time is now: 11th June 2024 - 10:24 PM |
