| Niklas |
Oct 1 2012, 12:57 PM
Porsche 914 Sweden ![]() ![]() Group: Members Posts: 368 Joined: 20-June 09 From: Sweden - Skivarp Member No.: 10,488 Region Association: Scandinavia |
Hello!
I am building a 914/6 GT clone. I need vented discs rear ? Who sells them ? Niklas |
| Eric_Shea |
Oct 3 2012, 03:48 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE Rotor Spacers under the hat is probably best bet as the those 911 rotors can have a mm step at the inside mount surface preventing flush seating to the hub Ut uuuuh. QUOTE Which rotors go with the "rare as hens teeth GT calipers"? Do you have to modify anything? 1. Factory GT rotors @ $250.00 (which really isn't that bad when you consider you probably won't ever have to get another pair). 2. 911 Rear rotors with the following mod(s): a ) 5mm spacers under the caliper ears, or b ) 5mm spacers under the rotor hats. |
Niklas 914/6 GT rear brakes Oct 1 2012, 12:57 PM
Niklas Anyone ?? Oct 3 2012, 02:52 AM
bulitt I believe the 914-6 used a solid rear rotor. The ... Oct 3 2012, 03:48 AM
bcheney PMB is a great source for everything about braking... Oct 3 2012, 04:40 AM
mepstein 914-6 GT rotor from PMB Performance Oct 3 2012, 06:25 AM
Eric_Shea GTs have vented rotors. Two models I've seen:
... Oct 3 2012, 07:14 AM
rdauenhauer Rotor Spacers under the hat is probably best bet a... Oct 3 2012, 08:00 AM
bob Which rotors go with the "rare as hens teeth ... Oct 3 2012, 09:15 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:39 PM |
