Adjustable pushrods, Any one in the bay area got one they would loan? |
jeffdon |
Oct 6 2012, 04:25 PM
Senior Member Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
Will need it in a couple weeks.....
VaccaRabite |
Oct 6 2012, 04:29 PM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
You need to make sure that the adjustable pushrod you use uses the same ends as the ones you will be putting in your car, or your measurements will be off.
At least, it makes life a LOT easier for you. Zach |
jeffdon |
Oct 6 2012, 05:55 PM
You need to make sure that the adjustable pushrod you use uses the same ends as the ones you will be putting in your car, or your measurements will be off. At least, it makes life a LOT easier for you. Zach Good pont Zach. Sometimes I think I may just put the stock valve train back in! It ran good for 8k miles, before it decided it wanted to spit out a sparksplug |
VaccaRabite |
Oct 6 2012, 11:13 PM
You need to make sure that the adjustable pushrod you use uses the same ends as the ones you will be putting in your car, or your measurements will be off. At least, it makes life a LOT easier for you. Zach Good pont Zach. Sometimes I think I may just put the stock valve train back in! It ran good for 8k miles, before it decided it wanted to spit out a sparksplug Don't do that. You will compromise a new engine if you do that unless you are running stock gear. And the chromoly pushrods are fantasist. Better then aluminum. You can run 0 lash with the chromoly pushrods. Order 9 and make the 9th one adjustable. It's easy to do with a tap and some threaded rod and 2 nuts. |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:55 PM |
