Good bye to the BEAST!, Selling the Track-tuned V8 914 |
stewteral |
Sep 29 2012, 10:16 PM
Old Member Group: Members Posts: 384 Joined: 4-December 07 From: Camarillo, CA Member No.: 8,424 Region Association: Southern California |
Hi all,
It is the end of an era for me, but I'm selling my 914-V8 to go play with a Formula Ford. I've spent the last 8 years developing and tuning the car and believe it is the ONLY 914V8 with a chassis developed for road courses. I'll be out at the Streets of Willow Springs on 03 November for a last outing and then want to car to go. Feel free to come out, check out the car and see how it runs the track. So far, I've clocked a 1:26 laptime. For SALE: Porsche 914 Chevy V8 conversion car, $35k invested, Price $18,500 (11.0 second Qtr Mile) -Built 383 Chevy SBC, output 500 HP, 4-bolt Mains Comp Cams Roller-cam, pushrods and hydraulic lifters Eagle 4130 crank Eagle forged rods 10:1 Keith Black Hypereutectic pistons All parts balanced with harmonic balancer Stainless steel rockers Aluminum heads MSD Distributor & Ignition system Edelbrock aluminum intake manifold 750 Holley 4-barrel Carb Custom aluminum valve covers 180-degree headers Dual mufflers w/ Super-Trapps + Open pipe replacement for track days Canton Road Race baffled oil pan Canton 3Qt Accusump Dual oil coolers with fans All oil & fuel lines are Aeroquip Remote Meziere electric water pump – 55 GPM Camaro Aluminum radiator with dual fans Spare Chevy 4-bolt mains block -Transmission Porsche Turbo 930 4-spd trans with custom shift linkage Quaife Torsen Limited slip differential Turbo Porsche half-shafts and CV joints Custom flywheel with Porsche clutch Wilwood Hydraulic clutch master cylinder & peddle Wilwood Hydraulic clutch slave cylinder with Aeroquip flex-line -Chassis: the ONLY race track developed suspension conversion car now running Custom Dash: Porsche Tach, VDO Water temp, oil temp, oil pressure gages, Oil pressure & alternator warning LEDs. Transmission oil temp gage Full rollcage Racing seats 5-belt racing seat belts (driver) 4-belt racing seat belts (passenger) Racing Engineer tuned spring rates Custom front and rear swaybars Koni adjustable Sport front shocks Custom built dual adjustable Koni rear shocks Spare rear springs- 2 sets Rear suspension bracing for track cornering loads Removable rear wing for track Rennspeed fiber glass fender flares, rocker panels and nose piece with splitter Custom fiberglass side cooling scoops to Engine Compartment -Brakes Wilwood 12” x 1.25” vented rotor, all wheels Wilwood 4-piston Aluminum Calipers, all wheels Aeroquip brake lines Wilwood Dual master cylinder w/ balance bar aluminum peddle Remote reservoirs in front trunk -Wheels 8” steel rims with TA Radials (street) 9-1/2” front Aluminum wheels w/ Fresh Goodyear racing slicks (track) 11” rear Aluminum Wheels w/ Fresh Goodyear racing slicks (track) Documentation: Large 3-ring binder of Every part of the Chassis Large 3-ring binder of Every part of the engine. Large 3-ring binder of complete 930 trans shop manual Complete data support for all chassis and tire on-track settings. Track Support: Seller will attend buyer’s initial 2 track events to help in learning the car. Streets of Willow Springs recommended A custom towbar is also available. Best, Terry, Camarillo,CA 805-482-0322 |
westtexass2k |
Oct 5 2012, 08:58 PM
Newbie Group: Members Posts: 40 Joined: 31-December 11 From: San Angelo Tx Member No.: 13,954 Region Association: None |
Congrats on the sale of the car. That went really fast. It is a good deal for the new owner.
That beast is pretty quick. I looks like you were running about 2:12-2:13 on your clean laps. We ran there in 08 at the Grassroots Motorsports Ultimate track car challenge with our street car and we ran 1:58. You definetly had a few bobbles running backwards that could have made up a few seconds. It sounded like you were not running as hard as you could. I bet it could run down in the low 2:00-2;05 range. The same car we ran in 08 now has another 90 hp and another 50ftlbs of torque so it should be a little quicker maybe a 1-2 seconds. We had a horrible weekend at that event. We went off track first day and hit the curbing and broke the oil pan and tore out a suspension pickup point out of the rear subframe. We spent a good 12 hours getting that fixed and only got a couple of good laps in. Here is the video link if your interested http://youtu.be/WH4tKRD3LzE Good luck with the new ride hope it is as fun as the last one. |
stewteral |
Oct 8 2012, 05:03 PM
Congrats on the sale of the car. That went really fast. It is a good deal for the new owner. That beast is pretty quick. I looks like you were running about 2:12-2:13 on your clean laps. We ran there in 08 at the Grassroots Motorsports Ultimate track car challenge with our street car and we ran 1:58. You definetly had a few bobbles running backwards that could have made up a few seconds. It sounded like you were not running as hard as you could. I bet it could run down in the low 2:00-2;05 range. The same car we ran in 08 now has another 90 hp and another 50ftlbs of torque so it should be a little quicker maybe a 1-2 seconds. We had a horrible weekend at that event. We went off track first day and hit the curbing and broke the oil pan and tore out a suspension pickup point out of the rear subframe. We spent a good 12 hours getting that fixed and only got a couple of good laps in. Here is the video link if your interested http://youtu.be/WH4tKRD3LzE Good luck with the new ride hope it is as fun as the last one. Whoa! The Beast has NOT sold yet. So unless some comes by soon, I'll still be out at Streets of Willow wailing away with the 180 degree exhaust and open pipes. Terry |
Lo-Fi Version | Time is now: 9th June 2024 - 05:03 PM |
