Sea Dragon 914 |
Member ![]() ![]() Group: Members Posts: 114 Joined: 26-February 03 Member No.: 358 Region Association: Northern California ![]() |
I had a problem with my turn signal relay a few months back and ordered the aftermarket URO Relay as replacement. I should have known there was a problem as the relay didn't quite work right when I first put it in. I sent it back to the vendor for replacement as I thought the one sent to me was defective. They verified the part number and sent me a replacement. It worked the same way so I just kept it.
Anyway, the relay doesn't work anymore. Now both my interior turn signal indicators blink and my brake light indicator blink all the time. (IMG:style_emoticons/default/mad.gif) I pulled the relay out of one of my other cars and it immediately fixed the problem. So, I'm ordering the factory relay. Maybe these work in the 911s but they didn't work on my 914. Save your money and buy a genuine part if you need a turn signal relay. SD |
toolguy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,276 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California ![]() ![]() |
I had both inside indicator lights start blinking when I used the wrong wattage bulbs in the front TS lights. . . I discovered it only because I did a wholesale swap of all my bulbs with new ones. . the turn indicators worked fine before the swap, started blinking inside in unison after the swap. . . I put the old bulbs back in and everything worked OK. . . so I got different new bulbs in the identical factory wattage and everything resumed working. . . Don't know if that is your issue but it was sure strange when it happened to me. .
Lo-Fi Version | Time is now: 4th July 2025 - 08:56 AM |
