| Hine62 |
Oct 22 2012, 03:50 PM
Member ![]() ![]() Group: Members Posts: 132 Joined: 4-October 12 From: Binghamton, NY Member No.: 15,000 Region Association: None |
I need to put a new clutch disk in my 914. Can I just upgrade to the 911 six spring or do I need to replace the pressure plate also? (Bearing will be replaced too.)
Hine62 |
| mr914 |
Oct 22 2012, 04:49 PM
914 Hillbilly ![]() ![]() ![]() Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None |
Depends on the usage, and how good of a driver you are..
I've been using the same pressure plate for20 years... Seem to go thru more core motors than clutches... W/ 2-4 track days per yer Look for wear, grooving on the p plate blur hot spots on the clutch or pplate Then it's a matter of, if you fix it yourself (IMG:style_emoticons/default/smash.gif) or pay someone else... If you are a checkbook jockey, Payton put the whole kit in. You do it yourself... Think, it only takes a couple of hours to swap one out That is, if you know what you are doing and you don't have to DPO... |
Hine62 new clutch disk... Oct 22 2012, 03:50 PM
76-914 any self respecting mechanic is going to R&R t... Oct 22 2012, 04:02 PM
Hine62 My dad's a mechanic and said just replace the ... Oct 22 2012, 05:08 PM
JamesM
My dad's a mechanic and said just replace the... Oct 22 2012, 10:57 PM
rhodyguy add a new throwout arm pivot clip, the ball cup bu... Oct 23 2012, 10:26 AM![]() ![]() |
Lo-Fi Version | Time is now: 10th March 2026 - 12:06 AM |
