first gear, it is a bitch sometimes |
johnpierre |
Oct 26 2012, 12:58 AM
Member Group: Members Posts: 401 Joined: 11-September 12 From: culver city, ca Member No.: 14,913 Region Association: Southern California |
hey everyone
is it just me or does any one else have a difficult time selecting first gear when the car is at a stand still. if the stop permits, i.e. a stop sign, or a traffic light that is just about to go green and i am rolling i can put it in 1st no prob, but if i am at a stop light with other car and waiting a while, in neutral and try to engage 1st gear it does not seem to want to move in to place with any kind of ease. it is really bumming me out. makes me feel like a 16 year old just learning how to drive. the trans and gear shifting is tight and without issue, so i don't thing there is a issue mechanically, but am i missing something or is this just a characteristic of this 914 transmission. i have already done to much "if (IMG:style_emoticons/default/hissyfit.gif) you can't find it, grind it." |
pete000 |
Oct 26 2012, 11:01 PM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
I have two 914s and one goes to first easier than the other, but neither are like a Honda.
I end up double clutching at the light and it seems to get into first after sitting. |
Dr Evil |
Oct 27 2012, 06:22 AM
I have two 914s and one goes to first easier than the other, but neither are like a Honda. I end up double clutching at the light and it seems to get into first after sitting. What that means is that your clutch is not disengaging fullly/its rubbing. When you clutch you release the load on the gears so shifting should be easy. Letting it sit for a while means nothing if the clutch is doing its job of on/off. With some drag there is force on the shifter sleeve and you will have the problem you describe. Cable shifters are not going to fix the internal problems with the shifting. I have some designs to make the trans shift like it is gated, and for a simple but effective cable shifter, but I have not had the time to prototype them. I wish I had a person with a running 914 closer I could experiment with. |
Lo-Fi Version | Time is now: 1st June 2024 - 12:02 PM |
