02loftsmoor |
Senior Member ![]() ![]() ![]() Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region ![]() ![]() |
Ok Campers Do I have this mounted on the correct half of the engine??? (IMG:style_emoticons/default/confused24.gif)
Attached thumbnail(s) ![]() ![]() |
two-strokejohn |
Member ![]() ![]() Group: Members Posts: 81 Joined: 30-March 06 From: Orient, Ohio Member No.: 5,793 Region Association: North East States ![]() |
Yes, but if you intend to split cases or do clutch work, you'll have to remove your flywheel first. I've got mine apart right now.......... removed all the outer stuff first to lighten and gain access before putting it on the stand. I stand corrected..... it goes on the other side . I had the other half on the stand while I was cleaning the case. The reason you want it in the other half, is because you can insert the crank ,cam, and all other parts when you are assembling the crankcase assy.
Lo-Fi Version | Time is now: 13th August 2025 - 09:52 PM |
