| kbrunk1 |
Oct 30 2012, 09:15 PM
Brunk ![]() ![]() Group: Members Posts: 180 Joined: 13-November 11 From: Dallas,Texas 73 2.0 FI Member No.: 13,778 Region Association: South East States |
OK got the Pelican Valve Adj Made Easy
Got in 5th - driver side wheel in the air -- have rotor at notch. Found Paint on flywheel and notch in housing so I am close to TDC of cyl 1. I can not bend enough to see anything on the flywheel standing from the wheel behind the drivers wheel looking in the hole. Now Pelican says in Figure 11 there is a small opening you can see from under the car near the top of the transmission (? front of the engine bar I assume - found all the tin but no opening. -- you can feel it with your finger ???? (not) Now I assume you pull the covers off with both wheels on? and Pelican says you need to mark the bottom of the flywheel in the gap I can not find. Is this hole on the Oil filer side? Stuck! |
| tdgray |
Oct 31 2012, 06:25 PM
Thank God Nemo is not here to see this ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,706 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
Better yet....look up a word in the dictionary ....mechanic....find one
| scotty b |
Oct 31 2012, 06:32 PM
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
Better yet....look up a word in the dictionary ....mechanic....find one How aboot a little compassion here Todduh (IMG:style_emoticons/default/dry.gif) No need to be a |
kbrunk1 Help First Time On Valve Adjustments Oct 30 2012, 09:15 PM
914_teener
Got in 5t... Oct 30 2012, 09:57 PM
Krieger The cooling fan is on the front of the motor just ... Oct 30 2012, 10:02 PM
Dave_Darling If you're looking at the flywheel, remember th... Oct 30 2012, 10:17 PM
The Cabinetmaker Sounds like you have found the notch and paint mar... Oct 31 2012, 04:42 AM
balljoint Take a couple of big steps back and check to see i... Oct 31 2012, 05:03 AM
Spoke
Take a couple of big steps back and check to see ... Oct 31 2012, 10:35 AM
SLITS Use Cap'n Krusty's opposite valve method a... Oct 31 2012, 09:46 AM
SLKWrx
Use Cap'n Krusty's opposite valve method ... Oct 31 2012, 10:30 AM
The Cabinetmaker
Use Cap'n Krusty's opposite valve method... Oct 31 2012, 02:40 PM
Rand
Use Cap'n Krusty's opposite valve method... Oct 31 2012, 06:59 PM
MDG
Better yet....look up a word in the dictionary ..... Oct 31 2012, 06:30 PM
tdgray
Better yet....look up a word in the dictionary .... Oct 31 2012, 06:54 PM
Woody
[quote name='scotty b' post='1761164' date='Oct 3... Oct 31 2012, 06:55 PM
Woody Hi guys. :wavebye: Oct 31 2012, 06:45 PM
timothy_nd28 The Cap'n has the superior method. It's a... Oct 31 2012, 06:52 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th March 2026 - 10:39 AM |
