> Help First Time On Valve Adjustments
kbrunk1
post Oct 30 2012, 09:15 PM
Brunk
OK got the Pelican Valve Adj Made Easy
Got in 5th - driver side wheel in the air -- have rotor at notch. Found Paint on flywheel and notch in housing so I am close to TDC of cyl 1.
I can not bend enough to see anything on the flywheel standing from the wheel behind the drivers wheel looking in the hole.
Now Pelican says in Figure 11 there is a small opening you can see from under the car near the top of the transmission (? front of the engine bar I assume - found all the tin but no opening. -- you can feel it with your finger ???? (not)
Now I assume you pull the covers off with both wheels on? and Pelican says you need to mark the bottom of the flywheel in the gap I can not find.
Is this hole on the Oil filer side?
Stuck!
tdgray
post Oct 31 2012, 06:25 PM
Better yet....look up a word in the dictionary ....mechanic....find one
scotty b
post Oct 31 2012, 06:32 PM
rust free you say ?
QUOTE(tdgray @ Oct 31 2012, 04:25 PM) *
How aboot a little compassion here Todduh (IMG:style_emoticons/default/dry.gif) No need to be a dick yourself
tdgray
post Oct 31 2012, 06:54 PM
QUOTE(scotty b @ Oct 31 2012, 08:32 PM) *
My bad....twas a bit dickish
kbrunk1   Help First Time On Valve Adjustments   Oct 30 2012, 09:15 PM
914_teener   OK got the Pelican Valve Adj Made Easy Got in 5t...   Oct 30 2012, 09:57 PM
Krieger   The cooling fan is on the front of the motor just ...   Oct 30 2012, 10:02 PM
Dave_Darling   If you're looking at the flywheel, remember th...   Oct 30 2012, 10:17 PM
The Cabinetmaker   Sounds like you have found the notch and paint mar...   Oct 31 2012, 04:42 AM
balljoint   Take a couple of big steps back and check to see i...   Oct 31 2012, 05:03 AM
Spoke   Take a couple of big steps back and check to see ...   Oct 31 2012, 10:35 AM
SLITS   Use Cap'n Krusty's opposite valve method a...   Oct 31 2012, 09:46 AM
SLKWrx   Use Cap'n Krusty's opposite valve method ...   Oct 31 2012, 10:30 AM
The Cabinetmaker   Use Cap'n Krusty's opposite valve method...   Oct 31 2012, 02:40 PM
Rand   Use Cap'n Krusty's opposite valve method...   Oct 31 2012, 06:59 PM
tdgray   Better yet....look up a word in the dictionary ......   Oct 31 2012, 06:25 PM
MDG   Better yet....look up a word in the dictionary .....   Oct 31 2012, 06:30 PM
scotty b   Better yet....look up a word in the dictionary .....   Oct 31 2012, 06:32 PM
tdgray   Better yet....look up a word in the dictionary ....   Oct 31 2012, 06:54 PM
Woody   [quote name='scotty b' post='1761164' date='Oct 3...   Oct 31 2012, 06:55 PM
Woody   Hi guys. :wavebye:   Oct 31 2012, 06:45 PM
timothy_nd28   The Cap'n has the superior method. It's a...   Oct 31 2012, 06:52 PM
- Lo-Fi Version Time is now: 12th March 2026 - 10:40 AM
