> Another MS conversion, Progress, at last.
JimN73
post Sep 5 2012, 09:37 PM
I've been talking to McMark for some time about the MS/ignition upgrade. I decided to to take the plunge a few weeks ago and asked Mark to put it on his schedule.
Jeff (JSConst) had bought a kit from Mark and decided not to use it, so I bought it from him. All of the pieces are together and Mark has time starting on Sunday.
Unfortunately, my time is limited so I may not participate much. I will add updates as I learn of them, or Mark may do that if he has the time.
McMark
post Nov 3 2012, 10:31 AM
914 Freak!
I tried MAP only. I tried TPS only. I tried blended. I tried adding a reduced orifice to the MAP hose. I tried increasing the MAP sensor lag/smoothing. I tried more fuel. I tried less fuel. I tried more timing. I tried less timing. I looked at datalogs to see if it was a noise issue in the wiring.
Nothing made it go away.
I did some research last night and I will be working on an optional MAF solution for my kits, but I'll be finding a MAF that it sized more appropriately and go through the process of mapping my setup on a flow bench.
904svo
post Nov 3 2012, 11:10 AM
904SVO
QUOTE(McMark @ Nov 3 2012, 08:31 AM) *
Mark do what I did hook up the MAF to a spare channel and plot the curve and compare it too the MAP and TPS and see how smother MAF is while under load.
JimN73   Another MS conversion   Sep 5 2012, 09:37 PM
ConeDodger   Wow! I can't believe Jeff gave that up...   Sep 5 2012, 09:52 PM
JimN73   So am I. But he has a lot of projects and I think...   Sep 5 2012, 10:04 PM
jsconst   There were a few factors that prompted my desicion...   Sep 5 2012, 11:30 PM
JimN73   There were a few factors that prompted my desicio...   Sep 6 2012, 09:24 AM
JimN73   Well, I got the car to McMark's yesterday with...   Sep 10 2012, 10:15 AM
jsconst   Nice, that things going to drive like a whole new ...   Sep 10 2012, 04:58 PM
JimN73   Here's the e-mail I got from Mark this morning...   Sep 12 2012, 06:49 PM
JimN73   Mark has the car running. Not well at first, fixi...   Sep 13 2012, 06:44 PM
ConeDodger   Very cool!   Sep 13 2012, 06:47 PM
kg6dxn   Did you tell him it has to be done before the 914 ...   Sep 13 2012, 06:52 PM
JimN73   I was hoping to get it done this week so I could g...   Sep 13 2012, 07:09 PM
JimN73   The fuel pump started puking all over the place th...   Sep 26 2012, 07:50 PM
kg6dxn   I've had to prime plenty of electric pumps for...   Sep 26 2012, 09:16 PM
Jeffs9146   I have a couple of very lightly used newer 2.0L In...   Sep 26 2012, 09:46 PM
JimN73   Thanks, Jeff. I got this one at Parts Heaven, the...   Sep 26 2012, 10:08 PM
ConeDodger   I saw it running at The OC... Did you take it home...   Sep 26 2012, 11:15 PM
JimN73   I did bring it home. Mark wanted to take a few da...   Sep 27 2012, 08:55 AM
JimN73   Update: This has not beeen and is still not a pai...   Oct 19 2012, 12:06 PM
JimN73   This has not turned out as well as either Mark or ...   Nov 2 2012, 01:04 PM
r_towle   This has not turned out as well as either Mark or...   Nov 2 2012, 03:49 PM
Vacca Rabite   Interesting to read. I am getting the same setup a...   Nov 2 2012, 03:56 PM
JimN73   I'll keep you posted, Zach. It's hard to ...   Nov 2 2012, 07:43 PM
904svo   I was running a web 86B cam in a 2ltr engine. What...   Nov 2 2012, 10:27 PM
cgnj   I was running a web 86B cam in a 2ltr engine. Wha...   Nov 3 2012, 02:23 AM
rwilner   Have you guys tried to run in tps only? Mps only?...   Nov 3 2012, 06:40 AM
904svo   I was running a web 86B cam in a 2ltr engine. Wh...   Nov 3 2012, 10:11 AM
McMark   Hmmm... I'll have to do some research on MAF s...   Nov 2 2012, 10:56 PM
ConeDodger   Mark, Would TPS work at low vacuum then switch to ...   Nov 2 2012, 11:00 PM
3d914   Jim, I did one with a Web73 cam - though it's...   Nov 2 2012, 11:06 PM
ericoneal   If it helps at all, here is my msq file. The prev...   Nov 3 2012, 09:05 AM
kg6dxn   A Ford Mustang MAF is the easiest to configure on ...   Nov 3 2012, 10:02 AM
ConeDodger   A Ford Mustang MAF is the easiest to configure on...   Nov 3 2012, 11:09 AM
McMark   I tried MAP only. I tried TPS only. I tried blen...   Nov 3 2012, 10:31 AM
904svo   I tried MAP only. I tried TPS only. I tried ble...   Nov 3 2012, 11:10 AM
McMark   I believe you regarding the improvement of using a...   Nov 3 2012, 11:28 AM
JimN73   Thanks to everyone who has volunteered info. I...   Nov 3 2012, 11:55 AM
charliew   My experience is only with my sons sti suby. You m...   Nov 3 2012, 09:10 PM
DNHunt   I don't know if it is available with Microsqui...   Nov 4 2012, 08:18 AM
McMark   Tried TPS only and tried blended with varying amou...   Nov 4 2012, 11:51 AM
JimN73   :headbang: :headbang: Well, the MAF solution tha...   Nov 26 2012, 09:55 PM
904svo   :headbang: :headbang: Well, the MAF solution th...   Nov 27 2012, 08:55 AM
JimN73   :headbang: :headbang: Well, the MAF solution t...   Nov 27 2012, 08:11 PM
Vacca Rabite   The 9530 is mild enough to drive CIS. MS can drive...   Nov 26 2012, 10:27 PM
JimN73   If that's the case, and I thought it was, I ha...   Nov 26 2012, 10:39 PM
Vacca Rabite   Get on the MegasquirtII forums. Post your logs an...   Nov 27 2012, 05:24 AM
Vacca Rabite   Btw, the overlap period for the 9530 is 73.72 degr...   Nov 27 2012, 09:46 AM
ChrisNPDrider   For what it's worth (Not much) I have adjusted...   Nov 27 2012, 02:28 PM
JimN73   Here is the tune file that I'm using and a log...   Dec 1 2012, 04:14 PM
JimN73   Here is the tune file that I'm using and a lo...   Dec 23 2012, 06:28 PM
904svo   Check your grounds to the sensors you are getting ...   Dec 1 2012, 06:11 PM
Dave_Darling   Throttle position closing when you haven't tak...   Dec 1 2012, 09:20 PM
McMark   Yeah, it's looking like there is a noise issue...   Dec 2 2012, 12:52 AM
904svo   Mark the best way to trouble shoot your problem is...   Dec 2 2012, 08:31 AM
McMark   That's a good idea. I'm going to try shiel...   Dec 2 2012, 11:32 AM
karlo   You may be looking at a sensor issue, but the MAP ...   Dec 2 2012, 12:35 PM
JimN73   Good stuff. Thanks to you all. Sometimes having ...   Dec 2 2012, 02:51 PM
rwilner   Mark I looked at the log. Is the signal ground se...   Dec 2 2012, 08:27 PM
JimN73   Progress today. Mark got a VR sensor with a shiel...   Dec 17 2012, 07:12 PM
jsconst   Glad to hear you're getting it sorted out Jim,...   Dec 17 2012, 10:34 PM
McMark   Actually, it'll drive better at the AX than on...   Dec 17 2012, 10:56 PM
JimN73   Actually, it'll drive better at the AX than o...   Dec 18 2012, 07:30 PM
904svo   I had noise problem with COP'S that drove me c...   Dec 18 2012, 10:53 AM
McMark   Hmm, but I thought people usually added resistor w...   Dec 18 2012, 01:04 PM
JimN73   Last week Mark rewired the VR sensor with shielded...   Dec 22 2012, 12:09 PM
draganc   The link doesn't work....   Dec 23 2012, 12:56 PM
DNHunt   I'm not so sure this will help but, I shielded...   Dec 23 2012, 04:29 PM
kg6dxn   You can also try an additional battery ground cabl...   Dec 23 2012, 05:39 PM
mrbubblehead   and like we say at work.... no shield in the field...   Dec 24 2012, 02:49 AM
JimN73   I haven't been driving much, waiting for a new...   Feb 8 2013, 03:07 PM
JamesM   I haven't been driving much, waiting for a ne...   Feb 10 2013, 10:32 AM
Vacca Rabite   Air Leaks? Gas turning sour? Not it has been a whi...   Feb 8 2013, 03:32 PM
JimN73   thanks, Zach. I'm sure the gas is good. I...   Feb 8 2013, 03:37 PM
Vacca Rabite   Okay, my post was nearly unreadable. Thanks iPhon...   Feb 8 2013, 04:54 PM
scotty b   Okay, my post was nearly unreadable. Thanks iPho...   Feb 8 2013, 06:22 PM
JimN73   Thanks. Injection cleaner didn't work, I had ...   Feb 10 2013, 11:43 AM
JimN73   Little has changed. Mark built a fully shielded h...   Apr 26 2013, 05:02 PM
r_towle   inline fuel pressure gauge. Suspect the fuel pump?...   Apr 26 2013, 05:10 PM
kg6dxn   Before you junk it, Why not try a heavier flywheel...   Apr 26 2013, 10:47 PM
jpnovak   Looking at your datalog the car is running really ...   Apr 26 2013, 11:08 PM
Vacca Rabite   I agree with Mike. At this point you need a dyno a...   Apr 27 2013, 08:31 AM
JimN73   I went out this morning and got a pressure gauge (...   Apr 27 2013, 11:49 AM
kg6dxn   I went out this morning and got a pressure gauge ...   Apr 27 2013, 05:47 PM
JimN73   I went out this morning and got a pressure gauge...   Apr 27 2013, 06:11 PM
JimN73   I went out this morning and got a pressure gauge...   Apr 29 2013, 07:59 PM
ConeDodger   [quote name='kg6dxn' post='1856214' date='Apr 27 ...   Apr 29 2013, 08:35 PM
JimN73   I searched for dynotuning in the Bay Area and foun...   Apr 27 2013, 02:58 PM
jsconst   Glad to hear your making progress Jim, hopefully t...   Apr 27 2013, 08:41 PM
r_towle   Sorry to hear you are struggling so hard with the ...   Apr 29 2013, 08:24 PM
JimN73   I know, Rich, thanks. I bought the pump (rebuilt)...   Apr 29 2013, 08:39 PM
bfrymire   I know, Rich, thanks. I bought the pump (rebuilt...   Apr 30 2013, 12:18 AM
JamesM   I know, Rich, thanks. I bought the pump (rebuil...   May 15 2013, 05:06 PM
ChrisNPDrider   Good luck Jim! :beer2: :)   Apr 29 2013, 09:07 PM
aircooledtechguy   I would seriously contact Mario Velotta at www.the...   Apr 29 2013, 09:28 PM
JimN73   I would seriously contact Mario Velotta at www.th...   May 15 2013, 05:13 PM
kg6dxn   There is a dyno shop in hayward. They specialize i...   Apr 29 2013, 09:30 PM
jpnovak   I use the Ford F150/Crown Vic external pumps. The...   Apr 30 2013, 11:38 AM
JimN73   Progress!! In the last week or so Mark an...   May 15 2013, 04:56 PM
JamesM   Progress!! In the last week or so Mark a...   May 15 2013, 05:03 PM
JimN73   [quote name='JimN73' post='1864573' date='May 15 ...   May 15 2013, 05:11 PM
- Lo-Fi Version Time is now: 9th June 2026 - 03:49 AM
