| yeahmag |
Feb 2 2012, 12:49 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,468 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California
| yeahmag |
Nov 5 2012, 11:47 AM
yeahmag 2056 Build Feb 2 2012, 12:49 AM
RobW
Installed crank, gears, cam, and rods. Dry fit CB... Feb 2 2012, 01:01 AM
ThePaintedMan Cool! Wish I had the guts to attempt a rebuild... Feb 2 2012, 06:43 AM
jaxdream Will the fan housing bolt up / clear the new pump ... Feb 2 2012, 09:06 AM
mrbubblehead what are you going to do about your engine mounts? Feb 2 2012, 09:52 AM
yeahmag I will need to modify the fan housing to clear the... Feb 2 2012, 10:46 AM
mrbubblehead you are one step ahead of me. i am doing the same ... Feb 2 2012, 03:55 PM
yeahmag I ground about 2mm off that pump. Maybe more. I al... Feb 2 2012, 04:01 PM
mrbubblehead since im not using the stock oil cooler or stock o... Feb 2 2012, 04:16 PM
yeahmag How are you routing the oil for the pressure stage... Feb 2 2012, 04:19 PM
mrbubblehead i used this diagram http://www.914world.com/bbs2/u... Feb 2 2012, 06:18 PM
Valy
i used this diagram http://www.914world.com/bbs2/... Feb 2 2012, 11:20 PM
yeahmag Here are pictures of the pistons after going throu... Feb 2 2012, 09:41 PM
jmill :agree:
I was thinking the same thing. Somehow ... Feb 3 2012, 07:07 PM
mrbubblehead
:agree:
I was thinking the same thing. Somehow... Feb 3 2012, 07:22 PM
Woody You are going to love that engine. :Qarl: :beer2... Feb 3 2012, 07:48 PM
mrbubblehead any more progress yeahman? do you know what you ar... Feb 4 2012, 04:18 PM
yeahmag Been cleaning parts like mad. Finally ready to clo... Feb 14 2012, 11:32 AM
yeahmag OK. The long block is together and I'm startin... May 24 2012, 12:22 PM
yeahmag
After the copper spray to help with the carbon s... May 24 2012, 12:23 PM
yeahmag
Long block together (more or less). May 24 2012, 12:24 PM
yeahmag
Ported the hell out of the CB Dry Sump Pump and ... May 24 2012, 12:25 PM
Cupomeat
Ported the hell out of the CB Dry Sump Pump and... Nov 27 2012, 09:44 AM
yeahmag
Shot of the heads with Jakes "super" o... May 24 2012, 12:26 PM
Valy Those studs look to short to me.
And it looks to m... May 24 2012, 01:39 PM
yeahmag The nuts are just there to keep the rockers from f... May 24 2012, 02:10 PM
yeahmag Jake appears to like where I have my valve train g... May 29 2012, 06:05 PM
yeahmag Measuring my pushrod tips using a flat table and a... Jun 6 2012, 12:19 PM
Valy I would not measure them this way. Error is much h... Jun 6 2012, 03:40 PM
yeahmag Nah... The rig is designed for telescopes and is o... Jun 6 2012, 04:14 PM
yeahmag Here is a wider shot so you get a better feel for ... Jun 6 2012, 04:16 PM
Valy The cost of the measuring equipment doesn't be... Jun 6 2012, 04:24 PM
yeahmag I don't want to debat this too much, but this ... Jun 6 2012, 04:42 PM
Valy
I don't want to debat this too much, but this... Jun 6 2012, 05:39 PM
yeahmag This weekend I finished my valve train. I ended up... Jun 11 2012, 12:22 PM
yeahmag While not quite part of the engine build I thought... Aug 16 2012, 11:19 AM
FourBlades Cool engine build! :Qarl:
John Nov 5 2012, 12:30 PM
yeahmag Forgot to show the port matching of the CB manifol... Nov 5 2012, 04:59 PM
yeahmag A few more... I have the scavenge line run up the ... Nov 25 2012, 09:07 PM
yeahmag RE: 2056 Build Nov 25 2012, 09:08 PM
396 Cool engine build- oh thanks for the education too... Nov 27 2012, 09:00 AM
yeahmag Just the two lowers. Nov 27 2012, 10:39 AM
yeahmag Some craptastic iPhone photos of the progress. Pas... Dec 11 2012, 06:04 PM
mrbubblehead looks good. what size is that? -8, -10? Dec 11 2012, 07:15 PM
yeahmag -10 on the scavenge side. -12 for most of the run,... Dec 11 2012, 07:31 PM
Gint Nice! When do you fire it? Dec 11 2012, 07:39 PM
pete-stevers how did you bend the oil cooler? Dec 11 2012, 11:20 PM
yeahmag I bent the cooler in a press supporting it with 2x... Dec 12 2012, 10:56 AM
914_teener
I bent the cooler in a press supporting it with 2... Dec 14 2012, 02:22 PM
yeahmag Soon they will be packed full of DOT-R rubber piec... Dec 14 2012, 04:58 PM
yeahmag Here are some pic's of my mock up of the tank,... Jan 30 2013, 12:38 PM
mrbubblehead nice yeamag. i did the same thing with the T fitti... Jan 30 2013, 07:26 PM
yeahmag Good idea! Not sure it has any higher probabil... Jan 30 2013, 08:23 PM
mrbubblehead your right. piece of mind i guess. Jan 30 2013, 08:25 PM
yeahmag And passenger side is finally done.
Feb 10 2013, 10:59 PM
mrbubblehead looks good yeamag. those an fittings sure get expe... Feb 10 2013, 11:35 PM
yeahmag ...and yet more fittings to be ordered.
Feb 14 2013, 01:42 PM
mrbubblehead that looks awesome bro. im glad summit has the ret... Feb 14 2013, 02:43 PM
yeahmag Got a little bit more done. Been thrashing for a f... Feb 25 2013, 12:51 AM
yeahmag Really just a matter of making it look good and pu... Mar 4 2013, 10:53 PM
yeahmag ...and if anybody has any words of wisdom how to p... Mar 4 2013, 11:10 PM
mrbubblehead good luck bro. sounds like a good plan. the only t... Mar 4 2013, 11:55 PM
yeahmag I've actually read more than once that filling... Mar 5 2013, 12:50 AM
mrbubblehead
I've actually read more than once that fillin... Mar 5 2013, 01:19 AM
yeahmag Nope. I did remove the bypass and weld it shut in ... Mar 5 2013, 10:20 AM
mrbubblehead mine took alot of cranking to get the light to go ... Mar 5 2013, 12:10 PM
Racer Chris Aaron,
Did you grease the gears in the pump to hel... Mar 5 2013, 12:32 PM
yeahmag No. I've had bad luck with that in the past wi... Mar 5 2013, 12:37 PM
Racer Chris I think the type of grease used is critical to tha... Mar 5 2013, 12:51 PM
yeahmag Knowing me I used wheel bearing grease and screwed... Mar 5 2013, 12:53 PM
dfelz I like your set up a lot, looks really good. are y... Mar 5 2013, 05:36 PM
yeahmag Yes. No cutting of the body. Mar 5 2013, 05:46 PM
dfelz Very cool, i saw you had a CB dry sump pump, are t... Mar 5 2013, 06:09 PM
Racer Chris
... a CB dry sump pump, are the aftermarket pumps... Mar 5 2013, 08:04 PM
yeahmag Just a quick update. Priming the system was no har... Mar 11 2013, 09:59 AM
yeahmag Drove it in to work yesterday and man did that fee... Apr 3 2013, 11:07 AM
yeahmag First long distance outing was driving to Cal Spee... Apr 9 2013, 10:52 AM
yeahmag Had some minor surgery on my throat last Monday, s... Apr 24 2013, 09:17 PM
yeahmag It did make a "squeak" that seemed to be... Apr 24 2013, 09:24 PM
worn
It did make a "squeak" that seemed to b... Apr 30 2013, 08:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th October 2025 - 08:14 AM |
