| 3d914 |
Nov 7 2012, 06:43 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
I need a complete schematic of the stock ignition switch for 70-76. Already been through the elec diagrams on PP & Haynes - but not what I need. The Haynes one would work if they didn't split it up across two pages.
Also the other thing I need to verify (appears to be the case) - does the switch have mulit-decks? Meaning are there multiple circuits for each of the 3 positions (Off, run, & start)? TIA, |
| 3d914 |
Nov 7 2012, 09:12 PM
Thanks larry. 76 - the link is for the headlight switch. I'm after the ignition switch.
3d914 Ignition switch schematic? Nov 7 2012, 06:43 PM
larryM well, yes,
and, maybe
not all yrs 70-76 had the... Nov 7 2012, 07:29 PM
76-914 IIRC, Brad the DJet Oracle has a write up on those... Nov 7 2012, 08:48 PM
Jeff Bowlsby Its in the factory manual... Nov 8 2012, 11:07 AM
3d914 Jeff, does that schematic indicate clearly whether... Nov 8 2012, 01:27 PM
SLITS
Jeff, does that schematic indicate clearly whethe... Nov 8 2012, 02:09 PM
Jeff Bowlsby 'Multiple decks' is a physical constructio... Nov 8 2012, 02:13 PM
Nine_14 http://www.pelicanparts.com/914/914_electrical_dia... Nov 8 2012, 02:43 PM
3d914 OK, the factory switch schematic helped me, so I t... Nov 9 2012, 06:58 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:57 PM |
